Problem selecting 1st and 2nd
Hello, My 74 911 just developed this problem with no warning, just all of a sudden.
I was driving the car and it was shifting fine, then something went wrong, now when I select 1st gear, I get 3rd. when I select 2nd gear I get 4th. 3rd and 4th gates still work fine, but when I select 1st and 2nd gate I get 3rd and 4th gear instead. Some times (maybe 1 out of ten) I get 1st and then it shifts into 2nd no problem and then into 3rd no problem and then 4th, but when I try to get back to 1st, 2nd gate, I am still stuck in 3rd 4th gate. Maybe this has already been discussed, if so please direct me to the solution. Thanks, Scott |
Sounds like the shift coupler in the tunnel behind the front seats has come loose.
Pull inspection plate and check. Has the linkage been adjusted in recent times? |
I had a similar issue, it turned out the joint on the shifter shaft below the stick its self, was cracked, here is the thread of the issue
http://forums.pelicanparts.com/porsche-911-technical-forum/604784-1978-911sc-shift-linkage-question.html Sounds like it is the coupler for you, or the bushings in it. They are easy to replace, some where on here is a tutorial of how to realign the shifter as well it is quite useful. Best Dave |
Bad bushing at the bottom of the shifter! Thanks for all the advice!
| All times are GMT -8. The time now is 02:38 PM. |
