toddu's Avatar
Spring plate cover alignment
After installing poly-bronze bushings, I seem to have a slight spring plate cover alignment issue. On the passenger side everything lined up fine. On the drivers side I had to run a file one 1 side (same side) of 2 of the holes to get the bolts to lign up where I could tighten everything up. This was during the "testing" before the torsion bar was in. There was no binding once I tightened everything up.
Just wondering if this is normal? Obviously the rubber bushings allow for a fair bit of give one way or another, where the polybronze won't, so maybe not completely surprising.
Todd
'81 SC
Old 09-06-2011, 05:40 PM
Tom '74 911's Avatar
This is on par w/my install of the ER polybronze bushings. I had to get creative by stacking washers as spacers to even the cover plates out. I wouldn't worry. Be sure to leave some free play (in/out) when the spring plates are fully installed and tightened down, otherwise you'll get excessive wear on the insides of the bushings (as me how I know). The instructions clearly state this and as long as you follow them, you should be good to go.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-06-2011, 06:21 PM
toddu's Avatar
Yes, I have lateral play fine, what I was referring to was having to elongate 2 of the 4 holes. Not by much, 1.5 mm at the most.
Todd
'81 SC
Old 09-06-2011, 06:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Post a pic?
'85 Carrera Targa
PCA/POC
Old 09-06-2011, 09:17 PM
PMB Performance
Eric_Shea's Avatar
I honestly can't see how that would happen unless the bearing on the body isn't flush. See the notes about grinding the factory welds in the instructions.
I made a grinder that sits flush over the bearing opening and laid it on there until everything was flush. I used an old cut-off wheel on a backing plate.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 09-26-2011, 02:20 PM
PMB Performance
Eric_Shea's Avatar
Here's some pics of my recent install with the cut-off/grinder mentioned above. This may help:
Crappy pics but, torsion tube ground flat for Elephants:
The backing plate on the cut-off wheel was just the right size:
Used the surface of the cut-off wheel to level the tube surface:
Using the cover plate and some wood blocks to push the bearing in:
All the way in and flush:
Done:
855-STOP-101
Old 09-27-2011, 01:02 PM
