Taking it apart is easy
The hotter it gets, the harder it shifts
Often, on transaxle oil threads, people mention that "X" transmission oil allows smoother shifting while the engine/trans are cold. The assumption is that the smooth shifting continues once the transmission has warmed up.
I switched to Kendall and , yes, it does shift nice and smoothly while cold. However, the hotter the transmission gets, the harder it is to shift gears. If I want to shift from 4th to 5th, for example, with it hot, I have to really shove hard to move out of 4th, and then shove hard to go into 5th. There is no problem with the synchros, they are fine, it's just hard to move the lever. I have adjusted the clutch and the shift coupler (it has new bushings) until I like the action of each, but what is this business of the shifter stiffening up after running for a while?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com Last edited by Jerome74911S; 07-25-2011 at 08:05 PM.. |
Member 911 Anonymous
Strange, mine is very happy when hot
![]() Calling Peter Zimmerman!!!! Have tried double clutching? What was in it prior to the change, how many changes of Kendall did you do? I did mine 3 times (1000 miles per) to insure getting all the old stuff out.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-26-2011 at 12:25 PM.. |
I experienced this behavior once and it ended up that my gearbox was actually low on fluid. Once I topped it off, the problem went away.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
"shove hard to move out of 4th" - Your clutch is not fully releasing
Diss Member
If that is the case it also means the syncros are being damaged until it is fixed.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Is there some mechanism at work where heat can cause the clutch to not release fully?
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Racer
Try Swepco!!
![]() Scott |
I didnt see a year.....but Swepco worked well in my 99' however per PZ I am running Kendall in the 915 and it transformed the shifting!! That said the clutch should be checked for proper adjustment including the floor board stop and your seat position (just sayin)
Ed M 86' Coupe |
Hey Jerome,
You stated clutch engages above the middle of the pedal travel. It needs to engage at the middle, if properly adjusted. I would lean towards the cable adjust to 25.0MM difference. When was the last time the Clutch Fork was replaced? Jim BTW fellas, she is a 74 per his Garage.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Yup, the car's a '74. That means no omega spring, or any of that fancy stuff, so does a "25.0MM difference" apply here - or am I misunderstanding something? It seems that clutch adjustment is more of a black art with this car. I agree that the clutch should engage at the middle, but in trying to solve this problem I now have it a bit above the middle, but not by much. That change didn't resolve the issue, nor did it make it worse.
I just recently put the trans back onto the engine, and the lot into the car. The clutch fork looked quite good, so I reinstalled it - it was pivoting very freely, too. A new input shaft oil seal was installed (part # 915 302 381 00, I think), and the splines were clean on the shaft. I didn't do the seal installation, but it seemed to be straight and clean. Also, there was no visible leakage from the flywheel oil seal. The flywheel appeared to be brand new, so it was not removed. The above being said, there is a small seepage of oil visible at the bottom of the bell housing.
I use Swepco and tranny used to be difficult to shift after prolonged sessions on the track on hot days (never had trouble on the street) and I added the WEVO cooler and it never gets hot enough for shifting quality to degrade now.
Welcome to Windrush Evolutions - WEVO - Porsche Products
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
As I just read the Haynes manual Section4 regarding your year, for that matter all years, the required Differntial of cable travel must be 25.4MM. Kind of coincides with the 3.2 (thru '86) specs of 25.0MM (+/- 0.5MM)
I have a Haynes manual on the shelf; I'll check it out.
Bentley or forget it.......spend a few bucks and stop messing with the Haynes, use the pages to soak up oil that is on the floor
Ed M 86' Coupe |
My Bentley manual is oilier than my Haynes. In any case, the Bentley doesn't cover my '74.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com Last edited by Jerome74911S; 07-27-2011 at 12:06 PM.. |
Can it bee the litel beering in the in flywheel that is the problem when ewrything its hot.
Jocke |
I'm open to any idea, but I sure don't want to have to take the thing all apart again. Therefore, verification of this suggestion will be useful before I crawl under the car, wrenches in hand.
How many times has the hard shifting happened? Mine got stuck in 5th gear three times one night a half year ago I drove home in 4th, hasn't happened again. I was/is using Swepco.
