Chain fence eating turbo
Newbie Motronic to MegaSquirt question
Can you take the fuel/ignition maps off the Motronic chip (in my case a custom burned chip for my turbo) and plug the info into MegaSquirt's tuning software?
Old 09-28-2011, 04:49 PM
probably not.. there is alot more to setting the MS up than just the map, you need to deal with injector pulse widths etc.. all well documented in the various MS forums. I'm sure someone here has done a conversion and could provide you a base map and base settings. The motronic maps are also likely in a format that is not easily convertible to the MS maps.
Old 09-28-2011, 06:11 PM
Lame. I have the ignition per RPM on and off boost.
Just needed fuel tables.
Old 09-28-2011, 06:17 PM
