-   -   Speedo turn signal indicator not blinking (http://forums.pelicanparts.com/porsche-911-technical-forum/631999-speedo-turn-signal-indicator-not-blinking.html)
alf 09-28-2011 07:18 AM
Quick help request as the search did not turn up any results.
The turn signal indicator on my speedo is not blinking. Turn signals work fine, checked fuses by battery, nothing blown. Is there another fuse location? Relay? or wire i should check?
thanks!
Joe Bob 09-28-2011 07:50 AM
Checked the bulb? Power to the bulb? Ground is to the gauge and can get crusty, clean and re-install...
86 911 Targa 09-28-2011 07:52 AM
thanks!
The indicators are located on the tachometer.
Do you have a Bentley manual?
Possible open ground behind tachometer.(G116)
Neel 09-28-2011 08:55 AM
Check all the above,, It also may be as simple as the bulb socket falling out do to prior poor install.. I've seen this happen before..
john walker's workshop 09-28-2011 09:11 AM
some chinese and non-stock relays do that.
alf 09-29-2011 07:28 AM
Thanks, I will take a peek at it this weekend. The unit is stock afaik.
