Speedo turn signal indicator not blinking
Quick help request as the search did not turn up any results.
The turn signal indicator on my speedo is not blinking. Turn signals work fine, checked fuses by battery, nothing blown. Is there another fuse location? Relay? or wire i should check? thanks!
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
RETIRED
Checked the bulb? Power to the bulb? Ground is to the gauge and can get crusty, clean and re-install...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Do you have a Bentley manual? Possible open ground behind tachometer.(G116)
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Check all the above,, It also may be as simple as the bulb socket falling out do to prior poor install.. I've seen this happen before..
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
some chinese and non-stock relays do that.
Thanks, I will take a peek at it this weekend. The unit is stock afaik.
