BW
Rear Window Trim Question
I have an '89 Carrera that I'm planning to polish the black anodized trim to bright silver. In searching the forum I've found good info on how that's done. However the other day I noticed the rear window doesn't have any metal trim--it's all rubber. How do I go about adding metal, silver, trim to the rear window?
Thanks,
BW 1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff |
you can't insert the metal trim without removing the seal. unless your seal needs replacing (window leaks) you are probably better off leaving it alone unless you want to buy the trim, as the seal is not easy to replace because of the defrost wires.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Depending production date on your car you would have to change seal all together. The older windows have the metal on them. Hope this helps at all.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
BW
Thanks guys. That's what I was afraid of.
