where is this relay?
Thanks for looking.
So I noticed that the windshield washer pump on the front is not getting power. Hence causing this weird issue of leaky cap problem The pump works if I hot wire it. Hence i am suspecting the relay (additional cleanning fluid pump relay) Anyone knows where it is? or has a part #? http://forums.pelicanparts.com/uploa...1317484542.jpg Thanks, |
Found it !!
The switch was fine. The relay part #928 618 113 01 The relay did not test well. It is located behind the RPM gauge |
Bravo Zulu (Well Done).
When in doubt, always check the Windshield Washer Pump Relay Locker, Port Side Aft :) Old Navy Joke :) |
| All times are GMT -8. The time now is 07:10 AM. |
