where is this relay?
Thanks for looking.
So I noticed that the windshield washer pump on the front is not getting power. Hence causing this weird issue of leaky cap problem
The pump works if I hot wire it. Hence i am suspecting the relay (additional cleanning fluid pump relay)
Anyone knows where it is? or has a part #?
Thanks,
Mauricio
87 Carrera Targa
Old 10-01-2011, 09:04 AM
Found it !!
The switch was fine. The relay part #928 618 113 01
The relay did not test well. It is located behind the RPM gauge
Mauricio
87 Carrera Targa
Old 10-01-2011, 11:44 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Bravo Zulu (Well Done).
When in doubt, always check the Windshield Washer Pump Relay Locker, Port Side Aft
Old Navy Joke
Who Will Live... Will See
Old 10-01-2011, 03:49 PM
