-   -   Interference fitting heater tin (http://forums.pelicanparts.com/porsche-911-technical-forum/632652-interference-fitting-heater-tin.html)
john baldwin 10-02-2011 08:56 AM
Any suggestions on ways of moving the camshaft oiler piping on the left side of the engine to allow clearance for the early version heater ducting would be appreciated. Its the last step in backdating my heat and i don't want to start bending small dia pipes in case there's an easier way.
john walker's workshop 10-02-2011 09:28 AM
if your metal line is straight as it goes into the horizontal line, then there's another pair of lines that moves the attaching joint inward a bit. the metal line would have a bit of a S curve at the top.
john baldwin 10-02-2011 07:00 PM
Not sure I understand what you describe; attached is a photo of the oil line
http://forums.pelicanparts.com/uploa...1317607235.jpg
