dazed and confused
Interference fitting heater tin
Any suggestions on ways of moving the camshaft oiler piping on the left side of the engine to allow clearance for the early version heater ducting would be appreciated. Its the last step in backdating my heat and i don't want to start bending small dia pipes in case there's an easier way.
89 Carrera 3.2 Targa 2011 BMW 335d 2013 BMW X3 3.5 80 911 SC Weissach Coupe (Sold)
if your metal line is straight as it goes into the horizontal line, then there's another pair of lines that moves the attaching joint inward a bit. the metal line would have a bit of a S curve at the top.
dazed and confused
Not sure I understand what you describe; attached is a photo of the oil line
