robeph
3.0 chip
can a 3.0 sc be chipped
Old 10-04-2011, 04:01 AM
a.k.a. G-man
Geronimo '74's Avatar
no.
Old 10-04-2011, 04:14 AM
robeph
thanks Geronimo,just purchased a 1981 sc and trying to find out the most cost effective way to improve performance
Old 10-04-2011, 04:18 AM
Mothy's Avatar
Send a message via AIM to Mothy
Robeph
Some searching on this site will uncover this topic being discussed many times. It's a great resource and take the time to try different key words for the search.
One theme for SC's that will come up often is the best way to improve the performance is to leave the engine alone and concentrate on the weight of the car - there are a number things you can do to strip out almost 70kg and that does make a big difference.
By the way - there is also an Australia/NZ regional forum here where you will find a lot of Australian based members.
Good luck - I have an 83 SC with US spec engine and it performs just fine!
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 10-04-2011, 04:34 AM
a.k.a. G-man
I'll elaborate my answer a bit.
Porsche only started using the DME in 84 I believe. (digital engine managment came with the 3.2 engines)
Cars that do not have the Bosch DME cannot be chipped simply because they don't use a chip to begin with.
Old 10-04-2011, 04:42 AM
robeph
Tim,thanks,sounds like a great start i will do that when i finally get the car/
How do i find the Australian regional forum?
Rob
Old 10-04-2011, 04:48 AM
Rob H
Here is the Australian site, not up to the US site though. New Zealand / Australia - Pelican Parts Technical BBS
I am from Adelaide with a '89 3.2 Carrera and love driving it almost every day.
Good luck securing your SC.
Another Porsche Rob from Adelaide
Old 10-04-2011, 05:51 AM
