1974 911 w/ 83 SC engine
How do you remove the starter ring gear from the pressure plate?
How do you remove the starter ring gear from the pressure plate seen here? I don't see any bolts, but there are a couple fasteners that look like heavy duty rivets. But there doesn't seem to be a way to remove them. I have a new pressure plate coming in and need to take the starter ring off of this one to install it on the new one. Thanks!
Old 10-05-2011, 04:33 PM
Friend of Warren
Once you have removed the 9 8mm Allen head bolts that hold the pressure plate to the flywheel, and it appears you have, just get a plastic or brass hammer and tap the ring off. Some just fall right off. Some need a little persuasion.
Kurt V
Old 10-05-2011, 04:57 PM
Haha, yeah, some rubber mallet-ing was all it took! Man that sucker was on there though. Thanks!
Old 10-05-2011, 05:39 PM
Northern Motorhead
wildcat077's Avatar
Great timing for the post guys ... i have to remove mine as well as i'm currently replacing my rubber centered clutch disc which exploded two weeks ago !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-05-2011, 05:44 PM
vash's Avatar
dont forget to put it back..
poof! gone
Old 10-05-2011, 08:03 PM
HAHA, yeah, that I read about when searching! I can 't imagine the chain of cuss words that would come out of my mouth if I re-installed everything, went to turn the key to start the engine, and just heard the whine of the starter motor!
Old 10-05-2011, 08:07 PM
tobluforu's Avatar
If anyone needs a brand new one, I have one that was never installed.
Old 10-06-2011, 07:24 AM
kodioneill's Avatar
Using a mapp gas torch, heat the ring and it'll fall right off. Wear some heavy gloves during the r&r. Reheat it to install, make certain it's facing the correct way.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-06-2011, 12:34 PM
As said before...don't forget to put it back. Very annoying to get it all back together and see that thing sitting there, staring at you like you're a dumbass. Not that I would know anything about that...
Old 10-06-2011, 02:25 PM
1988 Carrera
shadowjack1's Avatar
I turned my around to expose "new" teeth. The old side had some worn spots.
Old 10-06-2011, 03:55 PM
Flipping the ring gear..That wont work until you get to 87 or a turbo
Bruce
Old 10-06-2011, 04:51 PM
