-   -   OK to use a TORX 55 socket to remove flywheel ? (http://forums.pelicanparts.com/porsche-911-technical-forum/633413-ok-use-torx-55-socket-remove-flywheel.html)
wildcat077 10-06-2011 03:39 PM
Hey guys,
I would like to know if it's allright to use a TORX 55 socket to remove the flywheel bolts.The Torx is a six point socket and it seems the bolts are 12 point and require a special socket ...
Cheers !
Phil
RWebb 10-06-2011 03:43 PM
No!
Use the correct triple square
JohnJL 10-06-2011 03:44 PM
If you strip it out it is a pain...you can get triple-square bits from sears.ca or Babco.
wildcat077 10-06-2011 03:54 PM
Thanks guys,
That's what i was thinking,just called my local auto parts supplier to order one ...
Is it OK to use an impact gun to remove the flywheel bolts ? It worked well for the pressure plate fasteners !
Cheers !
Phil
RWebb 10-06-2011 04:09 PM
sure
masraum 10-06-2011 05:40 PM
Hmm, I've seen the correct tools for sale at several regular old auto parts stores.
Porsche wasn't the only manuf to use them.
Maybe it's different up there, eh? ;)
Tippy 10-06-2011 05:45 PM
I've used a Torx to remove and replace my flywheel bolts a couple of times. No problems, just keep square to bolt head and lots of pressure holding it against the bolt.
wildcat077 10-06-2011 06:04 PM
Steve,
Not to worry,i found a set that i will be picking up after work tomorrow!
Imagine that !
One cannot have too many tools :)
I'm in the middle of an engine drop due to an exploding clutch and i caught the "while i'm there " syndrome ... lol
Cheers !
Phil
Cheers !
Phil
masraum 10-06-2011 06:11 PM
You can usually pick up a set of 4 at places like O'Reilly, Autozone, etc...
You could always order them from Pelican Parts for $14.75
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT332_pg12.htm
Lisle 60750
http://www.northernautotools.com/med...nt-bit-set.jpg
Tippy 10-06-2011 06:17 PM
Good to know.
Bob Kontak 10-06-2011 06:28 PM
Napa is pretty common in Montreal. They have them.
J F MECANIQUE INC
2251 SAINTE-CATHERINE ST E, MONTREAL
514-521-4949
My favorite parts store in Montreal was always Chez Paree.
Bob Kontak 10-06-2011 06:30 PM
I know New Beetles and Passats use them on drive axles. Probably Audi, too.
al lkosmal 10-06-2011 07:40 PM
Heat is your friend when removing these bolts. I use a propane torch to heat up the bolt (it doesn't take much) and they typically come right out. (using a triple square bit). W/O heat they are much harder to remove.
regards,
al
wildcat077 10-06-2011 07:41 PM
Can anybody confirm if i need an 11mm triple square bit for the flywheel ???
That seems to be the equivalent of a Torx 55 ...
Cheers !
Phil
efhughes3 10-06-2011 08:21 PM
I wouldn't touch these with an impact. Too easy to strip. With the flywheel locked down and a good-sized 1/2" ratchet or breaker, I've never had an issue to remove these. As mentioned, heat may be of assistance on those that need it.
Bob Kontak 10-06-2011 08:40 PM
No - See Masraum's link - they do not come in odd # metric sizes. (well, I don't think they do) Probably 12 but I cannot say for sure. I will check the Porsche parts catalog and report back.
Edit - nothing in the parts catalog that defines the bolt socket size with granularity. Also, the parts link provides nothing and the 901/915 clutch replacement provide nothing (tech info center)
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-102-206-00-M58&catalog_description=Flywheel%20Bolt%20%28sold% 20per%20each%2C%20%39%20req%2E%29%2C%20%39%31%31%2 F%39%31%31%20Turbo%20%28%31%39%37%38%2D%38%39%29%2 0
http://www.pelicanparts.com/techarticles/911_clutch_replace/911_clutch_replace1.htm (references "special tool") I remember it being 12mm.
RWebb 10-06-2011 08:42 PM
take a steel hammer & smack the bolt head flat on - i.e. normal to the axis of the bolt
masraum 10-06-2011 09:25 PM
I had a couple of fwd dodge/plymouth products that were vintage '78-82 that used VW 1.7L motors and transaxles. They used them for the head bolts. I believe I was also told that Ford Pintos used them for something too.
Bob Kontak 10-06-2011 09:53 PM
Not the sexy Horizon? Owned one. The intoxicating 1979 edition. What a babe magnet. Sadly, I had no soft Corinthian Leather. In fact, no air conditioning and vinyl seats (in Houston) and the friggin inner fender strut mounting shell rusted at the spot welds and pulled away from the inner fender requiring me to use 30" of all thread to pull the suspension back together and then the front engine mount rusted out and the engine dropped four inches. But I digress.
http://forums.pelicanparts.com/uploa...1317962859.jpg
al lkosmal 10-06-2011 10:09 PM
when you say it like that...it sounds bad.
JJ 911SC 10-07-2011 03:10 AM
Originally Posted by Bob Kontak (Post 6296498)
... My favorite parts store in Montreal was always Chez Paree.
That was my favorite buffet ;)
wildcat077 10-07-2011 03:15 AM
Still need to know what size triple square bit i need ... I measured the 55 Torx bit and it's 11mm,just need to confirm the triple square size ...
Cheers !
Phil
JJ 911SC 10-07-2011 03:44 AM
Phil
Its a 12 mm. I did not have to use air gum to removed them.
The trick is to be totally square off as the bite is very shallow.
I could ship you mine but thanks to Post Canada it would be cheaper to buy one.
http://forums.pelicanparts.com/uploa...1317984258.jpg
wildcat077 10-07-2011 06:06 AM
Hi JJ,
I ordered a 10 and a 12 from my local auto parts store,they're only $4.00 each so i'll be good to go.
Thank you for your consideration and the info!
I know you did an engine drop recently,any tips while i'm there !
Did you ever get your car back on the road this Summer ?
I have a crankcase gasket kit on the way so i'll be replacing whatever seals and "O" rings that come with the kit ...
Cheers !
Phil
JJ 911SC 10-07-2011 01:43 PM
Hey Phil
Yeah, finally got her on the road late August. Start on the second try, what a relief. The sound of the SSis mated to a 2In/2Out was worth the wait according to the guys behind me :D
Well might biggest tips is, resist the "while you are in there impulse" :) it could be expensive...
If you leak from anywhere, its a good time to fix them, especially the Oil Triangle of Death (crankcase breather, thermostat & the idiot light. Good time to change the Oil Idiot light, under $5.
Since you got a G50 transmission, the drop is straight down unlike with the 915.
Take a lots of pics and notes as you might not remember everything when the engine go back in.
Have fun
JJ
Mark Henry 02-02-2017 06:10 AM
Sorry to dig up an old thread, but if any Canadian peeps are looking for the tri-square bit/socket Princessauto (Canadian version of Harbour Freight) carries 4 different sets from $17. to $30.
SmileWavy
ChrisBennet 02-02-2017 06:25 AM
I have nice German ones (Stahlwille) but I was in a pinch
once and got some from my local parts place.
They don't have a socket that you could use a ratchet on.
Instead they have just a straight shaft; think of an Allen
key without the bend. You hold the non-triple square shaft
end with a socket.
They are apparently made of a structural cheese (soft).
They rounded over after a couple uses.
Not recommended.
http://forums.pelicanparts.com/uploa...1486045327.jpg
Driven97 02-02-2017 06:41 AM
I used this, <$7 at Amazon shipped. Don't know how I used to get by before internet shopping.
https://www.amazon.com/gp/product/B00ESN0032/
Mark Henry 02-02-2017 07:54 AM
If you do a lot of VW and Porsche work you need:
8mm, VW and 914 CV's
10mm, 996, flywheel and trans (I believe fly might be 12mm)
14mm, 911, flywheel, VW T4 auto trans flywheel (TC mount plate)
