Northern Motorhead
OK to use a TORX 55 socket to remove flywheel ?
Hey guys,
I would like to know if it's allright to use a TORX 55 socket to remove the flywheel bolts.The Torx is a six point socket and it seems the bolts are 12 point and require a special socket ... Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
AutoBahned
No!
Use the correct triple square |
Wer bremst verliert
If you strip it out it is a pain...you can get triple-square bits from sears.ca or Babco.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Northern Motorhead
Thanks guys,
That's what i was thinking,just called my local auto parts supplier to order one ... Is it OK to use an impact gun to remove the flywheel bolts ? It worked well for the pressure plate fasteners ! Cheers ! Phil
AutoBahned
sure
Hmm, I've seen the correct tools for sale at several regular old auto parts stores.
Porsche wasn't the only manuf to use them. Maybe it's different up there, eh?
Chain fence eating turbo
I've used a Torx to remove and replace my flywheel bolts a couple of times. No problems, just keep square to bolt head and lots of pressure holding it against the bolt.
Northern Motorhead
Steve,
Not to worry,i found a set that i will be picking up after work tomorrow! Imagine that ! One cannot have too many tools ![]() I'm in the middle of an engine drop due to an exploding clutch and i caught the "while i'm there " syndrome ... lol Cheers ! Phil Cheers ! Phil
You could always order them from Pelican Parts for $14.75 http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT332_pg12.htm Lisle 60750
Good to know.
Fleabit peanut monkey
Napa is pretty common in Montreal. They have them.
J F MECANIQUE INC 2251 SAINTE-CATHERINE ST E, MONTREAL 514-521-4949 My favorite parts store in Montreal was always Chez Paree. |
Heat is your friend when removing these bolts. I use a propane torch to heat up the bolt (it doesn't take much) and they typically come right out. (using a triple square bit). W/O heat they are much harder to remove.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Northern Motorhead
Can anybody confirm if i need an 11mm triple square bit for the flywheel ???
That seems to be the equivalent of a Torx 55 ... Cheers ! Phil
I wouldn't touch these with an impact. Too easy to strip. With the flywheel locked down and a good-sized 1/2" ratchet or breaker, I've never had an issue to remove these. As mentioned, heat may be of assistance on those that need it.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Edit - nothing in the parts catalog that defines the bolt socket size with granularity. Also, the parts link provides nothing and the 901/915 clutch replacement provide nothing (tech info center) http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=930-102-206-00-M58&catalog_description=Flywheel%20Bolt%20%28sold%20pe r%20each%2C%20%39%20req%2E%29%2C%20%39%31%31%2F%39 %31%31%20Turbo%20%28%31%39%37%38%2D%38%39%29%20 http://www.pelicanparts.com/techarticles/911_clutch_replace/911_clutch_replace1.htm (references "special tool") I remember it being 12mm. Last edited by Bob Kontak; 10-06-2011 at 08:54 PM.. |
AutoBahned
take a steel hammer & smack the bolt head flat on - i.e. normal to the axis of the bolt
I had a couple of fwd dodge/plymouth products that were vintage '78-82 that used VW 1.7L motors and transaxles. They used them for the head bolts. I believe I was also told that Ford Pintos used them for something too.
when you say it like that...it sounds bad.
