Intensive washer wires?
My 86 Carrera had the intensive washer system originally but was removed. I bought a tank with the pump. Where should I look for the wires going to the pump? The PO cut the hose at the tank but I don't see the plug. Where does it connect at the other end?
Thanks, Bernie |
RETIRED
Left front in the trunk in front of the battery.
My 83 has a black and a brown wire to the pump. Pump is mounted on the front faschia inside.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The intensive washer system was located next to the brake booster, not in front of the battery. The one in front of the battery is the regular washer system.
Here's a photo of an '86. JR
Thanks for the replies, but what I need to know is where does the power wire for the pump originate as mine appears to be missing.
Thanks, Bernie |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks, now all I have to do is find the relay.
Bernie |
Bernie,
I checked the Bentley, but found only the windshield washer relay, behind the oil temp and oil level gauge, or the wiper relay behind the fresh air blower. Maybe someone else will chime in on your question. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-09-2011 at 08:40 AM.. |
Relay.
Here's relay you are looking for.
Maybe behind the oil gauge. Let us know what you find. The pin numbers seem to match up with the CKT.
