Frozen brake caliper piston
One of the pistons on my 79 911 SC is frozen in the caliper. I've blocked the other piston and used compressed air to blow out the frozen one and it won't budge. Any ideas? What can I try next? Do you think the caliper will still be rebuildable when I finally get the piston out?
Cheers, Elliot |
Eliot:
Sometimes you have to put penetrating oil in and let it set. Also you may have to take channel locks & clamp on the shoulder of the piston that pushes against the pad and try to rotate it back & forth to loosen it. This shouldn't damage the piston to where it isn't usable (but don't get too radical about it). Plus you can always buy used calipers and new pistons for not too much. After you get the piston loosened and with a C clamp on the other piston, try to blow it out. But, try to block them to where you blow them out in stages so you don't have one completely out with the other still down in the bore. Good luck.
Marv Evans '69 911E |
Thanks Marv,
I got some PB Blaster soaking in as I type. Cheers, Elliot
Elliot Cannon Paso Robles, Ca. "Nationalism is an infantile disease, the measles of mankind". - Albert Einstein Maintain thy airspeed, lest the ground arise and smite thee. |
Hi Elliot,
Just finishing with my brakes and I had some difficult ones. I used a c-clamp to squeeze the stuck piston back in a little ways, then hooked it back up to the car's brake system. I monitored as my wife used the brake pedal. I clamped the one that moved to put pressure on the stuck one and it moved right out. I had to adjust the clamp to keep it out of the way several times. You may have to bleed the brakes to get the full pressure like I did. Good Luck and watch your fingers! PS...car has been sitting for 18 years, but the piston bores were perfect. 18 Years In Storage…1974 911 18 Years In Storage…1974 911
Dave Taylor 1974 911 Coupe 2.7 Guards Red/Black Trim, Tbitz EFI, MSD 1974 Super Beetle Sun Bug 1959 356A (sold) 1954 Hudson Hornet Project For Sale 18 Years In Storage 1974 911 My Car in the Pelican Gallery Last edited by Dave Taylor; 07-16-2005 at 02:20 PM.. |
I just rebuilt all my brakes on my 78SC. I agree with all of the above. Would add two points. I had to really crank up the air pressure on my compressor to brak one lose. One last resort, we were able to get one out use thsi metho - ntoice there is a small lip on the pistons. We were ablt to choax it out with a little persuaion with a wide cheisel and hammer.
Again becareful ! Earl
78 SC Coupe 93 RSA (Gone) |
I just now got the little sucker out. I was able to work it in and out a few times, clamped the other piston down, put some air on it and KAPOW! It came right out. Thanks for all the good advice.
Cheers, Elliot
My tip:
Chizels not necessary! My thanks to my mate Don who suggested this when air would not move mine (about 12 years ago!) Ive never forgotten this I was so happy, after many days frustration with 4 seized calipers on my project 911. If you're without compressed air, or air wont budge it, or if youre still stuck... try a hand GREASE GUN! 1. Disconnect caliper. Remove brake fluid from caliper. Spray in or preferably soak in WD-40 to penetrate for a few hours, in a container. 2. Try to carefully tap piston inward slightly to break the corrosion fusion. I used a socket of similar diameter to the piston and tapped this with a hammer gently and as squarely as I could. Move the piston just a few mm inward. 3. Loosen the caliper bleed nipple or replace with a new nipple if yours is corroded. 4. Attach and pump the GREASE GUN and build pressure gently and the power of hydrolics should do the rest! 5. Finish by washing out your caliper to disolve Grease, with petrol/solvent/cleaner etc and inspect your bores for corosion pits and damage. Hope this helps someone someday!
Bruce |
Senior Member
Bruce,
Totally agree! The grease gun method is a lot safer than cranking up the air pressure. You can really get hurt using air. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I know I am resurrecting a really old post, but have this same problem. How do you connect the grease gun to the caliper? Or If I use air, the same question applies- how do I hook it up? Any pictures would be great.
Mike 1986 930 |
You might be able to screw in a zerk fitting where the bleeder screw goes. Take a bleeder screw into NAPA with you to match the size. You'll also need to block the line holes with a suitable bolt.
I prefer to push the calipers most of the way out with the brake pedal. -Andy
72 Carrera RS replica, Spec 911 racer |
