-   -   S-Caliper Rebuild Question (http://forums.pelicanparts.com/porsche-911-technical-forum/634212-s-caliper-rebuild-question.html)
1-ev.com 10-11-2011 02:27 PM
Hey Guys!
My Front S-Caliper has a plate witch connects brake line to the caliper and it attached with 4 bolts =see between arrows= to the caliper with the possible O-Ring GASKET inside. My question is what is the part number for this O-Ring GASKET?
The ATE Rebuild Kit 901-351-998-00-M4 DOES NOT include it.
Also, If someone has pic of the S-Caliper with open lid, please post.
http://www.pelicanparts.com/more_info/Customer_Comment_Images/1318344136-1900.jpg
Thank you.
-Youri
Flieger 10-11-2011 04:50 PM
I would ask the brake guru, Eric Shea
Brake Restoration Service
He can help you with parts questions, not just restored calipers.
Jim75911S 10-11-2011 04:55 PM
+1 on Eric Shea.
kugelfischer 10-11-2011 05:15 PM
+ one more for Eric. He's your guy.
I also have a disassembled S caliper @ home if you need a photo still send me a PM and I'll post one up here.
K
1-ev.com 10-14-2011 01:43 PM
K
PM sent, THANK YOU!
-Y
kugelfischer 10-16-2011 08:42 PM
Here you go Youri.
I've got the back plate off. You can see the 4 bolts that hold the plate on the caliper body, and the interior of the caliper. You should note the channel on the caliper body with the O-ring that seals the back plate and keeps fluid from running out. The back plate also has the knock-back post on it.
Sorry for the late reply, I was off @ RRIV.
Cheershttp://forums.pelicanparts.com/uploa...1318822945.jpg
chris_seven 10-17-2011 12:39 AM
I bought a bagful of O ring seals made in EPDM for this application - send me a PM with an address and I will post you a couple.
DaveA 10-17-2011 04:04 AM
Stoddard has the O ring for the end cap, SIC-351-999-00, fits 1969-1973 911S.
R/Dave
1-ev.com 10-17-2011 07:02 AM
Thank you guys so much!!!!
You are the best!!!
Do you know by the chance that is the torque for those bolts?
Also, do you have any advice how to clean S-Caliper Aluminum surface? It looks like I need some sort of chemical solution...
Thank you in advance.
-y
1-ev.com 11-01-2011 12:10 PM
Bump
Eric_Shea 02-02-2012 10:57 AM
I doubt you're still looking but for others that might be...
Those should be 12.9 fasteners and spec is anywhere from 13-15lbft. I always go 15 on an X patern.
The seal is a 52x3 in EPDM
Check the lip on that cover as they often have corrosion or chunks missing from DAPO's cramming a screwdriver in there to get the cover off.
1-ev.com 02-02-2012 01:51 PM
Thank you.. :-)
Eric_Shea 02-02-2012 03:00 PM
Sorry... 51x3
