Exotic Vehicles are here
1-ev.com's Avatar
Question S-Caliper Rebuild Question
Hey Guys!
My Front S-Caliper has a plate witch connects brake line to the caliper and it attached with 4 bolts =see between arrows= to the caliper with the possible O-Ring GASKET inside. My question is what is the part number for this O-Ring GASKET?
The ATE Rebuild Kit 901-351-998-00-M4 DOES NOT include it.
Also, If someone has pic of the S-Caliper with open lid, please post.
http://www.pelicanparts.com/more_info/Customer_Comment_Images/1318344136-1900.jpg
Thank you.
-Youri
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 10-11-2011, 02:27 PM
Max Sluiter
Flieger's Avatar
I would ask the brake guru, Eric Shea
Brake Restoration Service
He can help you with parts questions, not just restored calipers.
Old 10-11-2011, 04:50 PM
+1 on Eric Shea.
Old 10-11-2011, 04:55 PM
kugelfischer's Avatar
+ one more for Eric. He's your guy.
I also have a disassembled S caliper @ home if you need a photo still send me a PM and I'll post one up here.
K
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 10-11-2011, 05:15 PM
1-ev.com's Avatar
Porsche Crest
K
PM sent, THANK YOU!
-Y
+ '68 911
Old 10-14-2011, 01:43 PM
Here you go Youri.
I've got the back plate off. You can see the 4 bolts that hold the plate on the caliper body, and the interior of the caliper. You should note the channel on the caliper body with the O-ring that seals the back plate and keeps fluid from running out. The back plate also has the knock-back post on it.
Sorry for the late reply, I was off @ RRIV.
Cheers
1973 Coupe
Old 10-16-2011, 08:42 PM
I bought a bagful of O ring seals made in EPDM for this application - send me a PM with an address and I will post you a couple.
Old 10-17-2011, 12:39 AM
Stoddard has the O ring for the end cap, SIC-351-999-00, fits 1969-1973 911S.
R/Dave
Old 10-17-2011, 04:04 AM
1-ev.com's Avatar
Thank you guys so much!!!!
You are the best!!!
Do you know by the chance that is the torque for those bolts?
Also, do you have any advice how to clean S-Caliper Aluminum surface? It looks like I need some sort of chemical solution...
Thank you in advance.
-y
+ '68 911
Old 10-17-2011, 07:02 AM
1-ev.com's Avatar
Bump
+ '68 911
Old 11-01-2011, 12:10 PM
PMB Performance
Eric_Shea's Avatar
I doubt you're still looking but for others that might be...
Those should be 12.9 fasteners and spec is anywhere from 13-15lbft. I always go 15 on an X patern.
The seal is a 52x3 in EPDM
Check the lip on that cover as they often have corrosion or chunks missing from DAPO's cramming a screwdriver in there to get the cover off.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 02-02-2012, 10:57 AM
1-ev.com's Avatar
Thank you.. :-)
+ '68 911
Old 02-02-2012, 01:51 PM
PMB Performance
Eric_Shea's Avatar
Sorry... 51x3
855-STOP-101
Old 02-02-2012, 03:00 PM
Tags
s-caliper front rebuild
