chrisp's Avatar
Weltmeister Front sway bar mounting. Install question.
I just took delivery of a used set of Weltmeister sway bars. I see that the front bar has two sets of two triangular pieces bolted together with a poly bushing inside. I am guessing that this is a through body design. Is that the case? Is there another way to mount these other than through the body?
Is there a tech article or any tips on installing these bars?
Thanks,
Chris
Old 03-22-2002, 02:31 PM
Chris,
Pelican has a tech article that describes this. You can find it here: http://www.pelicanparts.com/techarticles/914_front_swaybar/914_front_swaybar.htm
Regards,
Rick
Rick Katigbak
Gretchen - 1972 3.6 ST-Replica
No Name - 1966 911 - 2.7S powered
Old 03-22-2002, 03:16 PM
The only sway bar that fits under the car is the factory sway bar. All aftermarket front bars go through the body as seen/described in the tech article.
Sherwood Lee
http://members.rennlist.org/911pcars
www.seinesystems.com
Old 03-22-2002, 03:22 PM
chrisp's Avatar
Thanks guys.
Old 03-22-2002, 03:24 PM
