Sherwood - I've got both the nut and nutless types. The longer bolt specification seems bizarre, but I've never paid any attention to the difference.
For the ones with the nut, I'd weld the nut on. Counter hold was there if needed, but quicker all around. This is for race cars, where speed of R&R is important, as it happens way more often than the 10-20 years between removal for a street motor. I've worried about fatigue fractures, especially with the nutless variety. I've seen the pictures of them. But somehow it hasn't happened to me. I think a little gusseting of the nut or threaded area - there is plenty of room for that - would make that part bullet proof. Which seems rather more useful than welding flanges. Weight is a wash on yours? In which case, why not stay with the solid stock? Are stock pieces prone to failure? The one genuine RSR failure I saw on a guy's genuine RSR was concluded to be a manufacturing defect. It looked like those holes might be stamped, and something missed somewhere and left a mark on the solid connecting part above a hole. The adjacent motor console can stand a whole lot of Swiss cheesing with no problems. I don't recall that the factory did that for the RSRs, though. |
Walt, Agree. Welding a nut in place is a good idea. I suspect your lack of end failure might be due to more frequent R&R of your track drivetrain. Typically, threaded fasteners in intimate contact between lengthy service intevals or are assembled dry in corrosive environs tend to remain in more intimate contact. Add in massive torque from an impact gun or 4’ breaker bar to R&R that bolt and there you go.
each time you create a fold or a crease you in increase the cross section all though material is the same thickness. think of a sheet of paper, strategically crease it and you can stand it on its end. adding swaged holes is common practice in aircraft construction when weight is a critical factor. " Keep going until things break" ha! i like your approach. Colin Chapman style.... he did win a lot of races didnt he? :-) best ps did the RSR 3.0 went a step further and added below an I-beam section? |
Actually, that "keep going until things break was kind of disappointing to me. I was at a vintage race at Steamboat, admiring well drilled rear brake rotor hats. I was hoping to hear some kind of formula. R&D by breaking was a bit above my budget.
| All times are GMT -8. The time now is 04:47 PM. |
