-   -   RSR Type Engine mount cross bar (http://forums.pelicanparts.com/porsche-911-technical-forum/635107-rsr-type-engine-mount-cross-bar.html)
HJT911 10-17-2011 10:02 AM
Hi,
I'm actually thinking about drilling my standard Engine mount cross bar to give it that outstanding RSR-Look.
Has anyone out there experience in doing that . Need information reg.
How many holes; which diameter each, some reinforcement neccassary, etc.
Are there any risks connected with this (less rigidity and/or dynamic stiffness)
Thank you in advance and I am looking forward to receiving some helpful comments and pictures
HJT911
Flieger 10-17-2011 10:20 AM
It will be less rigid. The holes, even if smooth, create stress concentrations. If drilled and not deburred sufficiently, they will cause fatigue cracking.
I think the RSR mounts were originally stamped, which is a cleaner cut than drilling.
I would also want to reinforce the ends where the bolt tubes are mounted, and add a sort of I beam flange on parts of the crossbar to regain the rigidity lost with the drillings.
Schmierung 10-17-2011 11:11 AM
I have done it by hole saw and then radiusing the entire thickness by grinding and sanding. This extra work was not for beauty, rather to eliminate stress risers.
GrantG 10-17-2011 11:25 AM
Clint at Rebel Racing sells them:
Engine
HJT911 10-17-2011 01:31 PM
Thank's for the reference.
Had just a look at Clints homepage. Looks like the bar has also one flange only as it is standard and not two as it was for the original RSR Bar.
javadog 10-17-2011 02:14 PM
http://forums.pelicanparts.com/uploa...1318886069.jpg
RWebb 10-17-2011 04:13 PM
nice!
dad911 10-17-2011 04:26 PM
Very nice, and considering you can easily sell your un-drilled one if it is ok, it's a rather inexpensive upgrade.
Mr9146 10-17-2011 06:53 PM
Talk to Alan at Canford Classics in England. He makes very good quality reproductions at a very reasonable price.
The originals were curved on both the top and the bottom for rigidity and then the holes were punched to eliminate weight.
Racerbvd 10-17-2011 08:10 PM
I have an OEM that I can take some pix of if you need one to reference, but as others have already pointed out, you will weaken your bar and RSR bars have curved edges top & bottom which also helps rigidity.
That being said, I may order this one for my SC...
Rennline Stainless Steel Engine Mount Cross Bar - Porsche-Rennline, Inc.
snbush67 10-18-2011 12:02 AM
I used two different sizes for the holes.
http://forums.pelicanparts.com/uploa...1318921169.jpg
javadog 10-18-2011 04:47 AM
Those of you that are paying attention will notice that this is the same bar as previously mentioned as being sold by Rebel Racing.
JR
dad911 10-18-2011 05:16 AM
JR
Also sold by our host: Pelican Parts - Product Information: REN-M01S-RS
drcoastline 10-18-2011 05:26 AM
How much of an issue are the stress issues you guys talk about if the bracket is used on a basically stock motor?
sc_rufctr 10-18-2011 05:35 AM
This is an original one from an SCRS. ----- You gotta love ugly welds. ;)
http://forums.pelicanparts.com/uploa...1318941283.jpg
http://forums.pelicanparts.com/uploa...1318941298.jpg
http://forums.pelicanparts.com/uploa...1318941311.jpg
http://forums.pelicanparts.com/uploa...1318941325.jpg
javadog 10-18-2011 05:49 AM
Peter,
Do you happen to know which is the top side, as Porsche installed that in the car?
Thanks,
Jeff
quozl 10-18-2011 05:56 AM
This is the Rennline version that came with my car.
http://www.users.on.net/~quozl/Image...d/IMG_7486.jpg
http://www.rennline.com/images/m01s-rs.jpg
http://www.rennline.com/images/M01-RS-1.jpg
http://www.rennline.com/images/M01-RS-2.jpg
Cheers Al
sc_rufctr 10-18-2011 06:07 AM
Originally Posted by javadog (Post 6316980)
Peter,
Thanks,
Jeff
Jeff
The top is as you see it in the first photo. The side shown in that photo is also the side that faces the rear of the car.
I absolutely love how this thing is made. It's all about function.
javadog 10-18-2011 06:39 AM
Peter,
Thanks for the additional information. It's interesting to see how Porsche made these, and how the aftermarket "copies" are made in a completely different way.
Cheers,
Jeff
Flieger 10-18-2011 09:42 AM
You will want the extra rigidity of the I beam flanges on top and bottom.
The main issue is fatigue cracking. Drilling the holes will shorten the lifetime of the part but it is difficult to know by how much since it depends on how the hole is drilled and finished. If it is deburred and beveled nicely then it may not really be an issue, but stamping the hole out is better.
911pcars 10-18-2011 12:53 PM
The add'l metal along the top and bottom edge will add the needed rigidity reduced by the add'l holes. Net effects are offsetting, weight-wise. Has anyone compared?
Sherwood
Nate2046 10-18-2011 02:12 PM
I would NOT drill the standard bar. That thing is flexy enough without removing a bunch of material. I bought the Rennline version sold here to replace the bent OEM unit in my car. It's definitely a way sturdier piece and fairly cheap as far as upgrades go.
911pcars 10-18-2011 04:58 PM
I'm not totally sold installing holes is a bonafide upgrade unless the mount becomes both sturdier and lighter, but it does look racy.
Sherwood
Flieger 10-18-2011 05:34 PM
Sherwood
Ah, that is where you are wrong. You are moving the material around to change the distribution of the rigidity basically. By punching holes and adding I beam flanges of less mass than was removed, the whole thing will become more rigid in the fore-aft direction and in the vertical direction. Lateral will be less rigid by an almost immeasurable amount.
This is a case of making the best use of the least amount of material so that the material is not understressed from a % of yield strength point (extra weight) while being as rigid as possible.
911pcars 10-18-2011 05:52 PM
I think I'm saying the same thing in the context of comparing the weights of two examples.
Sherwood
Flieger 10-18-2011 05:55 PM
OK. I guess I did not understand what you were saying fully.
The rigidity/weight ratio goes up, but the strength goes down a bit if you reduce the weight.
Walt Fricke 10-18-2011 07:12 PM
http://forums.pelicanparts.com/uploa...1318989825.jpg
This one has held up fine for over 10 years of track only use. The machinist (an engineer) and I winged it on hole size and placement vs. how much web to leave in between. And no reinforcement either. I welded nuts on for the chassis mount bolts, and luckily have not bent those ends off despite being lazy and not counterholding.
I welcome fore and aft flex, as it makes getting the long bolts started easier - race motors go in and out a lot more than street motors.
Now if I could figure out the optimum pattern of holes in that exhaust support square tubing, I'd happily get to work saving an ounce or two.
Two of the holes in the motor mount proper are really useful. The small one upper right just under the crosspiece lets you get a socket wrench on the mount nut behind it. And the big hole opposite the pulley means you can get a wrench in on the pulley bolt easily.
The outermost two holes on the cross piece are a bit much, in retrospect.
Perhaps my good luck with this not failing might be due to using solid motor/transmission mounts? Less flexing leading to fatigue failures?
Mr9146 10-18-2011 08:20 PM
Naaaah. It's because you're not making any real horsepower! :D ;)
Flieger 10-18-2011 09:20 PM
Well, I guess the holes were small enough and you cleaned up the edges enough that the stress risers are small. It will still fail sooner theoretically, but it should be a LONG time.
jeff eelkema 10-18-2011 10:32 PM
[QUOTE=Walt Fricke;6318497]http://forums.pelicanparts.com/uploa...1318989825.jpg
Just curious, is some fore and aft flex going to cause gearshift issues or gear retention issues on acceleration or deceleration? Or does the gearbox mount do enough to stop any movement when the car is driven hard?
Walt Fricke 10-20-2011 02:44 PM
With solid mounts there is zero movement of the gearbox. The flex which sometimes helps me with installation is only in the rear mount crosspiece.
I usually leave the transmission in when pulling my motor. Saves lots of time. I used to chain the transmission up to the shock tower crossmember to support it.
Then I noticed it didn't need support! Not only did it not sag as you would expect when the motor was removed, but it even seems to rise up a little bit at the back.
I'm not recommending ignoring supporting it (lots of stress on the nose piece and so on), but it isn't budging if you have solid mounts.
Of course I am not making enough horsepower. Who ever is? For years it was 222 or so RWHP with the 2.7. The 2.8s are putting out 250 RWHP. I want at least 300 flywheel, but I'm not there yet, blast it. If that will break this piece, fine with me - at least I would have the power. I've got a stock piece in the trailer.
The one failure I observed (real RSR piece, too, not home brew) led to two laps of sparks before the driver realized it had happened. No serious damage.
I'd not consider holes in the crossmember for my street/track SC. Why? It has to make weight when raced, and the small reduction the holes make, the even smaller change in CG location, and the vagaries of highway driving (not a track with a tow truck handy and a trailer with spares and tools at hand) suggest not doing low value/some risk things.
strokher racing 03-30-2013 09:13 PM
How much lighter than stock is the rennline brace?
RWebb 03-31-2013 12:12 PM
make the center of it out of CF with the ends of inconel on screw threads to adjust for length :D
oh yeh - I drilled my cross bar too and powder coated it silver - not very functional, but...
tazzieman 04-01-2013 04:16 AM
Very little i.e. not significant enough for me to go and compare weights. It's a solidly made piece , even though it's full of holes. I can bend the stock one with my hands.
Toddlaunchbaugh 04-07-2019 12:26 PM
Great thread. But does any one know what the weigh savings actually is,
RWebb 04-07-2019 01:59 PM
engine support crossbar (stock 2.7L vs. 1986 with holes drilled) 3.0 -0.52 2.5 drilled 3.2L bar - RSR type
Toddlaunchbaugh 04-07-2019 02:16 PM
Thanks , Half a lb for $225 if you purchase one. I still struggle with justifying $100/lb
panzerfaust 04-07-2019 03:48 PM
All things being equal, yes adding the large hole will make it weaker
But if you swage the hole by altering the cross section it can become lighter and stronger than the original part with holes. I’m surprised it hasn’t been done yet
Walt Fricke 04-08-2019 09:27 PM
If this is what you see done in sheet metal reinforcements, isn't this material too stiff to be done easily? Wouldn't you need a hefty die and very strong press?
I'm nut sure why making it more rigid in the fore and aft direction is all that important. Porsche just made holes for the RSRs, didn't it. Solid transmission mounts will hold resist those forces.
Does swaging holes in sheet metal make if more resistant to bending when under compression? But here compression on one side is resisted by tension on the other, isn't it?
I'm not following the "lighter and stronger" part, though, assuming the holes are the same size. Isn't tensile strength more or less governed by the smallest cross sectional area? Which is at the 0 and 180 degree point on each hole? I've tried to keep those consistent hole to hole, though I have no idea what a reasonable minimum would be.
Since my home brew ones haven't failed, the old 356 guys would say I probably made them too small. Keep going until things break, then go back t the next smaller size seemed to be the mantra from the Swiss cheese era of lightening.
911pcars 04-08-2019 11:11 PM
My engine support bar weights:
- Factory support bar (below): 3 lb 1.4 oz (1400.47 gm)
- "Drilled", then reinforced along top and bottom edges, 3 lbs 13.4 oz (1740.66 gm)
http://forums.pelicanparts.com/uploa...1554785848.jpg
For comparison, an "RSR" spec support bar:
http://forums.pelicanparts.com/uploa...1554787597.jpg
BTW, early support bars use a nut/bolt (M12x92mm) attachment to each chassis mount. Later support bars delete the nut - the end boss is threaded to accept a hex bolt (M12x95mm). Unsure of why the difference in bolt lengths.
The solo bolt threaded into the bar end does not provide a counterhold during loosening and tightening procedures. This results in stress applied to the joint between the round end boss and the support bar. Numerous R&R cycles often/sometimes results in fatigue failure at that junction.
Short of using an RSR-spec support bar, I suggest reaming out (removing) the internal threads on later bars, then add a nut and washer attachment to mimic the early support bar mount. The hex bolt head thus provides a proper counterhold when tightening or loosening the clamping nut.
Early support bar:
http://forums.pelicanparts.com/uploa...1554787597.png
Late support bar:
Sherwood
