loose nut behind wheel
cudabnu's Avatar
MFI cams in a 3.0
Just finding out what the PO or shop did. Have a 78 3.0 that is getting a top and and re-seal, when I took it apart I found it had 72 cam towers and 911T MFI cams with the drive cam being machined down. As this was my first P-car I had nothing to compare it to, but friends that did drive it say it seemed faster than a stock 3.0
Thoughts on this set-up? should I put it back this way, or get the correct 4 bearing towers and stock 3.0 or 964 cams?
This is now my spare engine since I did a 3.6 swap, so I'm in no rush to put it back together, just more curious about the setup.
cam numbers are
911.105.133.0R
911.105.134.0R and a "3" stamped in the end.
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 10-20-2011, 08:22 AM
Bill Verburg's Avatar
cam numbers are
911.105.133.0R
the 911/51 engine(US MFI) has 10* less intake duration and the same exhaust duration as the SC cams, you need the total lift of each to compare further, I don't have that info.
My guess is that the T cams will have a bit less lift, if so then the T cam is certainly a milder cam than an SC
Bill Verburg
Old 10-20-2011, 09:13 AM
RETIRED
Joe Bob's Avatar
A decent cam upgrade for the 3.0 is the 964 or 20/21 if still using CIS. Won't pass CA smog though.
2012 ML350 3.0 Turbo Diesel
Old 10-20-2011, 11:45 AM
cycling has-been
bkreigsr's Avatar
Do the lobes show any signs of rework that might have been performed by WebCam, Elgin or John Doughterty? I had mine done by WebCam for the first rebuild, then John freshened them for the second. Bill K
Old 10-20-2011, 12:09 PM
db_cooper's Avatar
Sounds like MotorMisery..if the cams were reground..they should have been marked by the grinder with some identification.
Old 10-20-2011, 12:17 PM
