-   -   Replace my O2 sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/635733-replace-my-o2-sensor.html)
Dreamer52 10-20-2011 02:58 PM
Hi All
I'm trying to replace my O2 sensor- I read a post that recommends taking the heat shield off to access the sensor. How do I remove the bolts that are holding the shield? When I try to loosen the bolt it just spins- is the some type of fastener on the other end? I've tried to attach a image to what I'm speaking of.
Sorry for such a simple question...
Carlhttp://forums.pelicanparts.com/uploa...1319151485.jpg
cashman 10-20-2011 04:21 PM
It looks like the heat shield has already been removed and you can see the exposed brackets with the bolt holes. Not sure what you are pointing too but I believe that protector piece just snaps on to the O2 sensor with the C-clip. Not sure what bolt you need to remove?
Bob Kontak 10-20-2011 05:03 PM
Did this picture come from the post you read? Are you speaking about a shield that is not in the picture because it was already removed?
Those bolts are held in place by the rectangular clips you see. If they were not installed properly I could see them spinning.
Give us a little more data.
DRACO A5OG 10-20-2011 06:28 PM
how about a pic of yours?
Dreamer52 10-20-2011 11:10 PM
The picture was from a posting, not mine. I think Bob is best describing what is happening. Can I just shear the top of the bolt off & replace? 2 of the clips have already been replace with bolt & nuts.
Carl
Bob Kontak 10-21-2011 12:11 AM
Heck yes, just cut them off. It's not like they are head bolts.
PDF page 95 in the parts catalog shows the cat for an 89. It looks a little different as to the shielding from your picture but you can search around and see if you can find the right clips and bolts and order from Pelican.
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_87_89_KATALOG.pdf
Dreamer52 10-21-2011 12:33 AM
Thanks Bob-
Didn't think about cutting them until after I posted...kind of a forehead slapping moment.
Thanks again
Carl
Bob Kontak 10-21-2011 02:32 PM
You can buy auto fastener hardware at Lowe's or Home Depot as well to expedite the job.
Dreamer52 10-21-2011 05:24 PM
Purchased a Dremmel today, working on the O2 sensor tomorrow. Thanks for all the help
Carl
Bob Kontak 10-21-2011 08:29 PM
When using the Dremel tool, do not force the grinding tool into the material to cut faster. The motors cook pretty quick under that kind of load.
Safety glasses - cut off wheels shatter with any side load - take your time.
