All-
Over the last several weeks I have been trying to locate a wur for my (1980 SC) euro spec WUR # 0438 140 069. If I cannot find an 069 then I could use an 090 or 072. My intention here is to not spam the forum, but I need your help. I am trying to get my 911 back on the road ASAP. If you have or know someone who has a WUR that they can part with I would appreciate your help. Even if you could point me in the right direction it would help. I could use any of the following WUR numbers in this order:
I will also post this to the wanted board as well- thanks for your help. |
Assorted WUR.........
SCSarge, I have a couple of -072 and -090 but none -069 from my junk box (wife calls them junk). Post a WTB in the classified section. What's wrong with your WUR? Send me a PM. ![]() ![]() Tony |
Now were talking!! PM Sent.
The voltage across my element is bad and won't stay in spec. |
do a search for rarely l 8 exhaust. brian is a great guy and i am sure he has what you need or knows where to get it.
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
voltage?
most check the resistance. perhaps you better splain lucy (ricky recarrdo acsent).
Crotchety Old Bastard
I did not notice earlier that your engine is a Euro. If this car has not been federalized and has the OEM fuel distributor you will need a -069 or -089 WUR.
I have a rebuilt -089 in stock if interested.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
![]() no need to splain, Lucy
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Got one -089 WUR ('80-'83)SC Euro
SargeSC,
I could lend you this WUR if that would help you. PM me for details. Tony |
Just to throw out a little bit of advice from personal experience. I had problems with my engine running. We went around and around trying to figure out what was wrong and why we couldn't get it running right. We kept coming back to the WUR. In the end, we went through THREE WURs, each from reputable places, until it was finally fixed. But, don't think we went through three in a row! We got one, figured all was good - but still problems. So, we tried a bunch of other things, just to try another WUR. THree times! But, finally the WUR it was and it took three. So, be careful and don't think because you get a WUR and your problems are not solved that your problem is something else.
FWIW, my car would get too rich at higher RPMs and they couldn't adjust it to be right at low RPM and higher RPM. It was one or the other. Finally, a proper working WUR solved it all. Jay |
...... which is why I only sell rebuilt WURs. Used WUR's are cores as they may not function any better than the used one on your car.
Used WUR's.........
Tony |
Thanks everyone...
I appreciate the knowledge that you all have had around helping me out. I did buy an 090 from a member on this board. So far so good-
As I mentioned earlier, my SC is a euro model and as far as compatibility the 090 works well in place of the 069. I hope that this info will help someone out in the future. |
your only contribution to the thread is a spelling check? follow me around, you will likely have more good input.
| Tags |
| euro , warm up regulator , wur |
