-   -   Subwoofer in front trunk? (http://forums.pelicanparts.com/porsche-911-technical-forum/63627-subwoofer-front-trunk.html)
Mukilteo911 09-30-2002 12:02 PM
I would have to say that the door of any car, including the 911 is a huge sub cabnet. If it is properly ported and a speaker with plenty of power installed, it will thump. I have a small home sub that has a 6 inch speaker in it about 12X16X16 and it thumps quite a bit in a house which has more space than a 911. A good speaker builder can calculate a port size and tube length for your doors.
Also look at sunfire subs, very small, much thump.
eurocarrera 09-30-2002 01:23 PM
Subwoofer under the Seat?
Has anyone ever thought of mounting a speaker under the drivers seat? I have the stock seats, and if I remember correctly, there is almost 10" of space with the seat in the very bottom most position. Even if the speaker was touching the seat, that would be OK (it's only sound waves), and you would be able to allow the port to face front or rear. You would also be able to strap or bolt the sub to the floor with a few "L" brackest which would allow you an all over kind of sound.
WydRyd 09-30-2002 03:45 PM
Is this the Infinity self-powered unit you guys are referring to?
http://forums.pelicanparts.com/uploa...BASSLINK_1.jpg
Features:
Built-in 200W Class D Amplifier
Remote Bass Level Control Included (BASSLINKLC)
10” Subwoofer with 10” Passive Radiator
Bass EQ -6dB to +3dB @ 40 Hz
Variable Crossover (50-100Hz) with 12 dB / Octave Slope
Verticle or Horizontal Mount Capability
2 or 4 Channel, Line or Speaker Level Inputs
Speaker Level Signal Sensing for Automatic Turn-On
Specifications:
Frequency Response: 20-120 Hz
Input Sensitivity Line Level: 50mV to 4V
Input Sensitivity Speaker Level: 1V to 16V
Fuse Rating: 25A
Dimensions: 14 1/2 L x 12 1/2 W x 8 D
Targa Dude 09-30-2002 03:55 PM
Yepper's... That be the one..:) and I'm 100% satisfied with all the features.. including size. In my installation I removed the smugglers box lid and mounted it right above. This unit is perfect for my car. I removed all air conditioning components long ago.
and mounted in this location does not interfere with anything at all.
Jorge (Targa Dude):cool:
Brian993 09-30-2002 03:57 PM
Merv -
Do you have this unit installed? Does anyone? I would like to know if its any good. It looks like a nice compact unit! I am sure it costs a few $$ but if it works good it might be worth it.
cab83_750 09-30-2002 04:05 PM
I had the bazooka, but the sucker sucked! I vote for the Infinity BassLink.
Awesome!
WydRyd 09-30-2002 04:07 PM
Brian, I don't have a subby as yet :(
All my speaker components are factory units, however, I plan to upgrade to 6.5" Focal PolyKevlar's in the doors. I'm a bass fanatic, so I may go for the Infinity boot solution. It has had many great reviews, so I don't think you can go wrong.
FYI, Sounddomain.com lists it for $399.95 (USD).
Brian993 09-30-2002 04:08 PM
$400.00 dont sound bad! It is definetly the missing link to my sound system. This is probably the only set back to 911 ownership!
WydRyd 09-30-2002 04:25 PM
Totally agree, the stock sound system in the pre-89 911's SUCK! I dunno about the later model 911's, mine just plain sux :mad: OK, there are times when I love to just listen to the roar of the twin tip exhaust, but sometimes I just wanna cruise and chill to some R&B ;)
Brian993 09-30-2002 04:28 PM
The stock system (speakers) in the 993 are very nice and with the cd unit I had installed (alpine) its quite nice. Some bass would bring it right up to snuff! I am going to investigate this a litte further by stoping in at the local vendor seeing what he thinks. I am just concerned about installing it in the trunk and having it muffled.
diy83sc 09-30-2002 04:35 PM
I have this one and have not yet wired it up.
http://www.epinions.com/content_51999706756
I can tell you it lay's nicely behind the driver or passenger seat (rear foot well) in my 83sc. It may not satisfy the audio critic, but should do better than the OEM speaker setup. I don't care to hack up the interior and prefer to leave in the factory 4x6 and 4 inch round grilles backed with some better speakers. If I need to, the kenwood can quickly disconnect by unplugging the connector. And if it doen't work out, I won't upgrade my headunit, visit ebay, and stick with the fine sounds coming from the exhaust ;)
Tony
Targa Dude 09-30-2002 04:44 PM
Hi Tony, That powered enclosure you mentioned is mostly a woofer the frequency response is way to high 35Hz to 1.5 KHz.. it's more of a mid range set up. Now the INFINITY is most definately a Sub.. with a Frequency Response of 20-120 Hz that is BASS!!! BABY!!
Targa Dude 09-30-2002 09:13 PM
1 Attachment(s)
Hey.. I found this picture.. sorry about the quality but, I think you can get a pretty good idea of how well it mounts in the forward compartment over the smugglers box
yooyanks 03-21-2012 03:16 AM
I put a kicker spec'd bandpass box in my porsche. It was 12x12 with an 8" solo baric woofer powered by a Rockford Fosgate punch 75. It sounded great!
ybn533 03-21-2012 06:16 AM
You can go this way. Under- seat sub:
http://forums.pelicanparts.com/uploa...1332339322.jpg
You can buy it here:
Kenwood KSC-SW10 (kscsw10) 150W 5" x 7" Powered Subwoofer Enclosure | eBay
For me it seems the best way to go.
Andy911sc 03-21-2012 06:32 AM
I am also running this under the drivers seat. Very easy to install and fits nicely. I ran the controller up to the center console, also the cable is really long for that and I shortened it. I am getting a custom bracket to mount it up to the seat mounting bolts, so it's not sliding around.
Here is a picture of where it sits, minus the bracket yet.
http://i1180.photobucket.com/albums/...c/IMG_0102.jpg
http://i1180.photobucket.com/albums/...n/IMG_0081.jpg
http://i1180.photobucket.com/albums/...n/IMG_0093.jpg
http://i1180.photobucket.com/albums/...n/IMG_0084.jpg
crustychief 03-21-2012 07:02 AM
Holy cow! a 10 year old thread!
BTW I have a bazooka on the floor behind the passenger seat.
ybn533 03-21-2012 07:08 AM
Who you're gonna kill with this bazooka? :D
SAY - 642 03-21-2012 07:18 AM
Sub
I purchased one of these from Car Audio Innovations.
I'm very happy with it, they matched it to my blue carpeting, and it's pretty stealthy. I have a dedicated McIntosh MCC301 amp pumping 600 watts to it.
Porsche Audio
http://i250.photobucket.com/albums/g...llenclinst.jpg
skunked 03-21-2012 09:31 AM
do you have any motor noise? maybe not because it's a sub but I noticed you ran the power and RCA wires together.
Andy911sc 03-21-2012 09:38 AM
This sub doesn't draw a lot of power (it's only a max of 150 watts), plus I got a higher grade rca wire with better shielding built into it.
now the amp in the trunk that powers the 4 speakers requires more power and I have kept those separate.
Tidybuoy 03-21-2012 09:42 AM
I'm in the process of building a sub box for my smugglers box which will hold an 8" Alpine sub woofer. I will be finished this weekend and will have some photos then.
I think the smugglers box is a great, stealthy, place for a sub but it's a bi&^% for measuring and re-measuring. I ended up making a mock box out of foam because I wanted to be sure the final product will fit thru the lid and be as large as the smugglers box can handle. The speaker will be pointed into the cabin thru the original A/C hole and the trunk will remain all stock. My amplifier is under the passenger seat.
962 03-21-2012 10:22 AM
Stereo
I ready to dump all my hi fi equipment. With the cd changer, amps and sub box,
must have close to 200 unwanted pounds:rolleyes:
Rickysa 03-21-2012 10:44 AM
I second the Car Audio Innovations....just did one in mine and it sure was easy. Hybrid L8's and DD amp, and am very satisfied.
DSouth 03-21-2012 11:42 AM
So far the best Sub-in-hood area solution I've seen is in this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/546879-1971-restoration-porn-ii-ultimate-hidden-stereo.html
Andy911sc 03-21-2012 12:17 PM
Originally Posted by DSouth (Post 6638136)
that set up is pretty sweet, but I was leery about putting a sub in the trunk because of how flimsy and light the hood is. All I could picture was the sound of it rattling as I drive down the road. I also didn't want anything that big. I am more of a complete sound kind of guy and didn't want bass to drown out my jazz.
dar636 03-21-2012 04:10 PM
Porsche Audio
Can you put the seats all the way back? I was told I could not, and sure enough that was the case when it arrived. I sent it back.
Nevergrowup 03-22-2012 02:08 AM
Being a hang-around in the car stereo community when the craze hit Norway in the early 90's, dreaming of both a 911 and a respectable boomin' system, I could not resist to equip my 911 with some woofers and an amp.
PO had installed a very good 2-way front system, with Focal speakers. Last year I put in an Alpine head unit, as I always lusted for back inthe days. Nothing fancy at all, but it has USB in the front. The sound was OK, but cruising at 70 on the highway you notice that you could benefit from some more power. So this winter I laid plans...
I ordered a small-ish 4 channel JBL amp that could be bridged, to run the front system and a sub or two.
GTO-504 - JBL
Beatiful design. Before fitting it in the car, it was sitting on the dining room table and my fiancee was sad when I removed it...!
Well, I wanted this system to be easily removable and not very intrusive. Also, I wanted to be able to remove the sub on trackdays or when I need the trunk space. The back seats are frequently used, so I had to fab something to put in the trunk.
The amp had to reside under the passenger seat, since I wanted sound with the sub removed, so I mounted it on a wooden plate, ran good quality cables to battery,ground and front system.
Now to the sub. My original plan was for a single 10 inch woofer, so I measured the trunk and used a woofer box calculator I found at the Rockford Fosgate site.
For simplicity I designed a closed box, needing smaller space and getting less booming sound than a ported box, although with less punch. The 27 liters I needed was quite small, and I wanted to use the full with to the left of the brake master cylinder, so I made a compartment with a lid next to the woofer area to put small stuff in - tools etc.
Ok, the RF Punch woofer I ordered was not in stock, and as I waited I got new plans... Two woofers are cooler than one, right? My box design had the woofer firing up, not ideal, but an 8-inch should fit vertically.... Being a lazy bastard I decided to redesign the box I had, and the specs on the Polk Audio woofers showed that 27 Liters was right for a ported box, but the port needed to be quite long.... How to fix this...?
If the woofer was to be used in a closed box it needed about 20 liters, and my 'tool box' was a little bigger than that. But hey! If I run the port from the left woofer compartment through the right compartment I reduce the volume a little, and get the correct length for the port tube.
So now I have one ported woofer for the booming bass, and a closed woofer for the dry, defined bass. In theory....
The 8-inchers was a tad big, so I had to add a top plate to get the woofer in place. But then the box became too tall...! Grrrr... OK, then I made the top 'profiled' and to replace the grey carpet I had to rip off during the redesign I used some from the trunk carped the PO hadn't cut to size. Two toned it is...
Peek-a-boo...
https://lh5.googleusercontent.com/-K...2012.11.52.jpg
And the sound? Friggin' great!
https://lh4.googleusercontent.com/-m...2019.57.50.jpg
https://lh3.googleusercontent.com/-7...2019.28.15.jpg
Scott Watkins 03-22-2012 06:17 AM
Tim, I had the folks at Custom Car Stereo do an audio upgrade on my 993 late last year. They did an awesome job on the project, including the fabrication and installation of the sub.
Audio system upgrade - Rennlist Discussion Forums
