doing 70mph...hit a bump...car died...now what?
i was driving into work this morning doing 70mph on the highway(fdr drive in nyc) when i hit a nasty bump in the road. the car immediately died. as i was now costing in neutral, i tried to restart the car while in motion but it was only cranking but didnt want to turn over. since i was doing 70, i was able to safely coast to the next exit and pull over. i checked to make sure my battery cables didnt bump off and they were good. i called AAA and had it flat bedded to my mechanic. it was a pretty nasty bump and i hit it on the drivers side. any ideas? my mechanic wont be able to get to it for a couple of days, just wondering what i should be in store for $ wise.
Old 06-16-2011, 12:50 PM
What car do you have?
It will help a lot if you mention what year and model of car you have.
Old 06-16-2011, 12:55 PM
Eddyvdw's Avatar
What model year is the car?
If it's an early/mid year model my guess would be fuel pump.
Ed
72 911E Targa (fun car)
BMW 535i Xdrive (work car)
Volvo XC90 Ocean Race (family car)
VW T2 Riviera Camper van
Banned
I doubt something broke, but I would just check all the connections. Maybe a spade connector came off of the distributor or the fuel pump or something. Check them all.
Also one of the fuses may of knocked out. Those old style fuses and their holders don't look to sturdy.
Check the ones in the back too.
Check the points. Maybe the connector got knocked off that.
Old 06-16-2011, 12:59 PM
na2ub's Avatar
I will place my bet on a fuse. I will even double down and say it is the big red circular fuel pump fuse in the front trunk. They have a tendency to wiggle out. Mine currently has a piece of tape over it. The proper fix is to pull it out and bend the prongs slightly outward so that it has a mechanical grip when reinserted. If you have a spare moment, go over to the mechanics, pop the fuse back in, and drive home. . Just make sure to fix it or tape it, as it will happen again (ask me how I know).
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 06-16-2011, 01:09 PM
dshepp806's Avatar
,..will be connection-related, for sure (well,...high probability!) Those fuses can do exactly as Doug mentioned.
Curious to see what this will cost?
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-16-2011, 01:13 PM
I agree check big red circular fuel pump relay. Same thing happened to me on BQE.
Old 06-16-2011, 01:15 PM
its a 79sc...ill check the big red fuse asap
Old 06-16-2011, 01:22 PM
na2ub's Avatar
Just in case that is not it (which I bet it is) check all the fuses and relays in the front trunk, and in the engine compartment (on the left side). Good luck!
Doug
Old 06-16-2011, 01:25 PM
Same thing happened to me and it was the ignition switch contacts that fell apart inside the switch as I hit the bump in the road.
Regards
Mike
RS #1551 (Sold)
67S
Old 06-16-2011, 02:14 PM
Driver
Noah930's Avatar
Agree with checking the fuses and relays in the front trunk, for starters. I had intermittent electrical issues. Turned out the plastic 10-fuse block that held the fuses had cracked and wasn't holding reliable tension across the fuses.
(It's not supposed to be split like that.)
1990 Black 964 C2 Targa
Old 06-16-2011, 02:20 PM
dshepp806's Avatar
WOW! MAJOR FAIL there!!!!!
Doyle
Middle Georgia
Old 06-16-2011, 03:15 PM
autobonrun's Avatar
Fuel pump relay came loose is my guess. I sometimes remove mine as a security measure when parking for long periods. Cranks but no go.
Old 06-16-2011, 04:57 PM
dhrcr911s's Avatar
Fuel pump fail - electircal or otherwise - if a fairly late model car...
If a carb car, this wouldn't stop the engine from running suddenly..
Electrical connector on the dizzy to the points - if a fairly early carb'd car.
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 06-16-2011, 05:16 PM
NOLAsc's Avatar
I'm betting it's simply the fuel pump fuse. Check to see if the wire on the top and/or the top side of the connector is fried.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 06-16-2011, 08:33 PM
Banned but not out, yet..
RSBob's Avatar
The same thing happened to me. Check under the dash that all your connector plugs are still plugged together. It was a 10 second fix - towing $120.
Old 06-16-2011, 08:59 PM
Mr9146's Avatar
Look at the CD box plug.
Old 06-16-2011, 10:08 PM
Almost Banned Once
sc_rufctr's Avatar
That happened to me after I serviced my car. I removed each relay, cleaned the contacts and reinserted them.
Then on the test drive the car just stopped... I checked the relay and the fuel pump one had dropped out of its socket. Plugged back in and all was good.
When I got it home I removed the relay again and opened up the splits a little bit at the end of the prongs and reinserted.
It has never been a problem since and that was 8 years ago.
- Peter
Old 06-17-2011, 12:22 AM
beamonk's Avatar
Send a message via AIM to beamonk
I had that happen once< the CD plug was loose and it burned out the hall effect coil in the Dizzy. Took a bit to figure that one out. I think the relay though.
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 06-17-2011, 06:32 AM
Having similar issues. '79 911SC Targa.
Checked and replaced fuel pump fuse, unplugged and check red relay.
Still a no go. Ideas??
also have thread that has car make and back fire in subject.
skime219
1979 911 SC
2014 911 Carrera S
2016 Mercedes E 400 Coupe
Old 06-17-2011, 08:40 AM
