Timing chain noise on deceleration?
Hello, My engine has about 3.5k on it since I rebuilt it last summer. it's an 80 sc 3.0. I am noticing a noise which sounds like the timing chain on the right side during deceleration. It seems normal on acceleration and idle. Is this something I should be concerned about? I put new pressure fed tensioners on. I'll try to post a video or sound clip if I can figure out how to do it.....
Thanks!
Old 10-24-2011, 10:18 AM
I wouldn't drive it until you take a proper look. this can be devastating.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-24-2011, 12:28 PM
I had the timing chain idler arm on my race car break, ended up grinding up the chain casing and a total rebuild. Old part failure. Don't drive it until you can pull the covers off and make sure that all is good
Old 10-24-2011, 01:19 PM
Good advise. I'll take the cover off this week and take a look. Anything specific to look at? I read post on tensioners loosing pressure. I'll see if the chain is tight. Also, look at the ramp....maybe its loose....Thanks!
Old 10-24-2011, 01:23 PM
