Bobmspeedster
New to this list and to 911's
I have a 1966 911 coupe is ther a way to improve the handling ie sway bar or cross bar? It feels light in the front end. I am a 356 guy so 911's are new to me. Bob |
Yep, a sway bar will improve the handling immensely. My SC is quite different form the early 911s so I would suggest doing a search here. I'm sure you will find what you need.
Also, try the earlys forum. Those guys really know those years.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Location: behind the redwood curtain, (humboldt county) california
Hi Bob, Welcome
Hi Bob,
I too had a early speedster and a 66 911, Then a 72 914, 77 308 ferrari and now a 74 911. I have (mis)spent my young adulthood thrashing, (auto-xing) and am now thinking about a few track days and a nice daily driver. To your question, it depends on what you want from/with the car. First you need to asses what you have and what condition things are in. A car of this age has got to have some serious issues unless it was well maintained. If I recall correctly, the 66 didn't come with a front bar, but first, i would be concerned with chasis integrity, (lack of serious structural rust or funky crash repairs), then bushings, then shocks & tires. As usual, budget, time and final desired outcome will set your goalposts. Is the car still a 2.0 with 6 single solexes??? Loved that car, chris |
AutoBahned
have you replaced the ball joints & front suspension bushings yet? do that first
how old are the shocks? what brand are they? in fact... is the car new to you? have you replaced the brake hoses and fuel hoses? those can kill you and/or the car |
Bushings, shocks and stiffer torsion bars will help, as well as a chin spoiler. Sway bars will help in the twisties only.
Start with the simple stuff first... check the tires, front end alignment, then bushings and ball joints.
'78 SC Wide Body, '81 Engine. M&K 1in2 Out, Carrera Sways, ER F&R rear monoballs, ER control arm bearings, ER spring plate bearings, turbo tie-rods, ER strut brace, Tarret Drop links, Bilstein custom-valved shox, Rebel Racing bump-steer kit, 22mm F, 28mm R TBs. Rebuilt calipers, new wheel bearings. |
Paper Member
My '65 has a front through-the-body sway bar. It was original equipment I think.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
You might consider a shock tower bar that connects the 2 front halves of the car. It wills tiffen the resistance for body roll if I am correct. I have used them in a number of vehicles including my 79SC and it tightens up the front end.
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
