Covering dash..
I went ahead and bought one of pelicans’ Dashboard Recovering Kit, Pre-Sewn, 911 (1972-94), German vinyl
Some on this board have bought plastic dash caps and had them upholstered. They then in turn attach/glue them to their existing cracked dashes. I just received the pre sewn material from pelican and in the pic I have attached, the red arrows show where the two pieces of vinyl are sewn together. The stitching follows the contour in regards to the red arrows, but a lot of pics I have seen have the stitching where the white arrows are. Has anyone else ever bought this kit before, if so do you have a pic of it installed? I was going to attach this myself, but after getting the material and seeing what I’m dealing with, there is no way in heel I’m trying this. I think it’s odd that the stitching is where it is??
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 10-04-2011 at 03:59 PM.. |
Chain fence eating turbo
Shrink the pic if too big and make sure it has the ".jpeg" suffix or it won't upload.
Ok, well I looked at some other pics of dash caps that are covered and it looks like there is stitching in the same spot I was trying to describe, it was just hard to tell by the pic. Off to the upholsterer it goes.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 10-06-2011 at 07:38 AM.. |
I've been thinking long and hard on my dash rework,..have all the samples/quotes from the big-boy upholsterers...sure is cheaper that way.
Today, I think I'm just gonna' pony up (save) for the real deal, factory replacement (big MF' $$$$$$$$)...but, by jove, she'll be remaining stock...... Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
72 911 Although it is done at the moment, it will never be finished. |
Please explain
Hi
I too have cracked dash. What is this kit you bought? I thought the dashes are leather? My 1973 has two cracks the big one at the right corner of the instrument dash and the little one from the speaker. I understand about not spending 1700 bucks, but has anybody just used a black filler and sand smooth, the challenge might be to not have any lines and just paint the small area. thx |
YEAP,..it IS a budget thing with me,...period. Like I said before, there's no question about the vendors out there who can produce super-quality reworks,...all with stitching of "some" sorts,..nice stuff, at that.....clearly.... My preference, "in the end"(not to reference RUSH!) is to have her stock. It is just recently where I've finally arrived at the decision. SO: on goes the "dash fund", as this will be an expensive run.....(I've done "those" before......--ahem---) NOW,..as to any comments with "fit",....has anyone here taken the FACTORY replacement path and encountered "fit" difficulties......(GOSH,..I couldn't imagine this!!!!!!!!!!!!!!!!),..not at that price!!!!!!!! I WILL say that it's great that the premier vendors (CRAFTSMEN) are proving such rich selections,..away from the stock,..but CLEARLY BEAUTIFUL STUFF...... 911 leather was PARTICULARLY responsive to my repeated questions....good group there,..and they turn the good stuff OUT! COVERS,...no way in heeellll, for me..... BEST! Doyle
Insert Tag Line HERE.....
My leather dash is fine. No cracks or such. Its the cardboard underneath that has bowed up in all corners.. Anybody make that part?. cheap?
The under lament is bonded to the metal part of the dash. Mine was so bad I had to buy a donor dash before I had Tony at Autobahn Interiors recover the dash in leather. He did a perfect covering job. Even then he had to make some repairs on the donor dash. The heat shrinks the leather and deforms the under lament. I believe the only thing you can do is to cut the under lament out and put a filler back in and reform it.
If you have a daily driver I would go back with vinyl or keep a dash cover over the leather dash.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Leather Dash
Rattlsnak, the problem is that your leather has shrunk so even though your leather hasn't crack you don't have enough leather now to go around the corners and down into the vents even if the under lament was repaired. Sadly, you probably need a new leather dash...
I had tossed about the idea of a new dash. I talked to one of the Porsche dealers about them and they very cautiously warned me of the difficult fit of the new dashes. He had said that several have been returned because the fit was so poor.
If you can re-use your dash to be recovered I'd go that way. VIP European Auto Interiors in Tempe, AZ has recovered 911 dashes without the seem or stitching and they come out looking great.
Kurt |
A leather dash is nothing but a regular dash with leather over the top. As it was mentioned, when it shrinks it warps the dash board under the leather. Time for a new dash board.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Actually, ran across a car today that had a GT Racing carbon fiber dash, and they simply covered it with some material. (not sure if it was leather, vinyl, or? ) Looked great and 1/4 of the price!
That's what I'm hoping to achieve, will post a pic of the covered cap if they were able to do it. Granted, I'm not covering a carbon dash. One issue about covering the cap is that it is so flexible and the guy doing it said it will be tough to stretch the vinyl on something that flexes so much.
For another idea, check out post 54+ here: 911 track car build.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...." -- William Faulkner |
As a quick and dirty fix, the plastic dash caps that our host sells is a good way to go. You can get a SEM vinyl rattle can paint to match your interior.. You'll have to cut down the warp parts around the vents and edges of your present dash so the new dash cap will lay down. Then use silicone to attach. Only use a dimes worth around the edges every 4"-5", then weight with sand bags or other material on the dash. I used cardboard tubes braced against the seat backs to push the face of the dash cap back into the windshield. It was a good fix until I could afford to recover the dash and I had reason to remove the windshield.
tobluforu, The only problem I see about screwing the leather/vinyl? down is that the screw heads will probably go right through the material before they suck down the backing unless you were to use fender washers. Plus when you use to 2 layers of Velcro the dash cap will ride up. I would think at this point the dash is a "write off" so I would go for the best look you can get and don't look back. Plus drilling holes through the dash and having sheet metal screws protruding into the dash area isn't the best thing. Once you start it might take more screws than you think...
I havent looked too deep into the dash cap usuage, as i dont really like the look of them. Its way too obvious especially around the corners near the gauges.
