sbmackie's Avatar
Shifter/linkage upgrades
OK, the 915 is coming out after the next event at Roebling in January.
Shifter/linkage upgrades: I'm doing the Seine unit. If the stock bushings are replaced and adjusted correctly with the bronze ones available from our host ($41) is there really any reason to put in either a WEVO or Stomski PSJ? Will I notice a difference? I will do new motor and transmission mounts at the same time.
Car: used AX/light DE/Street, usage percentage in that order. 82 SC with basically stock motor.
Can't afford the WEVO or Rennsport shifters.
Scott
Old 11-19-2011, 04:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Bronze bushing will definitely make an improvement and the Siense GSK will be awesome!
You are going Cabroilet mounts right? If so you will love them!
If cost is not too much of a difference, I would go with Ivangene's Derlin shift coupler
'85 Carrera Targa
PCA/POC
Old 11-19-2011, 05:27 PM
