This bracket used to attach to the fan blower bracket which is no longer there. What did you guys do with this?http://forums.pelicanparts.com/uploa...1320672902.jpg
bump
Matt
I barely reconized anything... is that a 3.0? On mine (3.2) there was no bracket. |
Phew, I tough I was loosing it...
It does not help when I'm 7605 miles (and 1 month) away from from the car :mad::mad::mad: If it was not for PP I woulg go nuts :) |
Is that just tape on the old fan wires? You need to fold and heat shrik those as they can still be energized by the controller in the cabin.
The bracket on my 3.0 came off with the fan so I can't help you there. You could just leave it there in case you want to go back to stock configuration some day. |
As far as the bracket , my fan support is gone (sold). Do you not have this condition on your car? Do you have a 78 or 79? Maybe that is the difference? |
Yeah, that piece isn't on the '78-'79 so I didn't have to deal with it. It looks like it would be pretty simple to fabricate a bracket out of a hunk of aluminum flat stock (1/2" x 1/8" or something). Just make an L shape coming up from the stud below.
a krylon cap and a hose clamp.
I built a bracket out of aluminum from Lowes just as described above.
http://forums.pelicanparts.com/uploa...1320892736.jpg |
| All times are GMT -8. The time now is 09:23 AM. |
