Notices
fred cook's Avatar
ATO fuse panel w/Headlight relays!
Ok, this seems to be what most folks want. I now have available an ATO fuse panel equipped with relays for high wattage headlight bulbs. With this installation you can run up to 100 watt bulbs without frying the wiring harness or switches. You get the advantage of using modern ATO fuses (fuses, smart fuses or circuit breakers), get the headlight relay kit preinstalled and mostly wired and still have a spare fuse for future adds! Of course it bolts to the stock fuse panel base.
Some pictures.
ATO fuse panel
ATO fuse panel with headlight relay kit
The short panel will be completely covered by the original fuse panel cover. The one with the relays will extend on the right end about 2 inches so you will have to modify the fuse cover slightly to clear the panel base.I have had one of the short panels in my car since 2004 with no problems. In fact, when I installed it, several "ghost" electrical problems vanished!
Line forms to the right, please!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 11-03-2011, 12:14 PM
fxeditor's Avatar
Okay Fred,
How much and where do I sign up!
-Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 11-03-2011, 03:14 PM
Fred
How do you connect the wiring?
The connections are like in the original fuse block or it is needed to crimp female spade terminals in all the cables ?
Old 11-03-2011, 03:31 PM
CabMike's Avatar
Fred,
I thought I was on the list from the previous posting but if not, please add me the the list including the headlight relays.
Thanks,
Mike Downs
Mike
1983 911 Cabriolet (3.6L conversion)
Guards Red
2007 BMW X5
Old 11-03-2011, 03:45 PM
RETIRED
Joe Bob's Avatar
Just a comment....ot two. Great work and idea.....
But the list Nazis have been working overtime. Might want to consider the FS forum and a price.
Fred, my offer is still open.
2012 ML350 3.0 Turbo Diesel
Old 11-03-2011, 03:54 PM
nineball's Avatar
i could have sworn i was on your list as well but never heard anything. i'm interested in one w/ the relays as i have a set of h4s sitting here waiting to be installed.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-03-2011, 04:14 PM
fred cook's Avatar
Fuse Panels
Every one that was on the first thread will be contacted in order. I
felt that this development deserved a fresh thread. Don't worry I will be in touch!
FEC3
Old 11-03-2011, 05:50 PM
fred cook's Avatar
Wiring connections
Originally Posted by donporfi View Post
Fred
Yes, you will have to add female crimp connectors to each wire. If you get the panel with the headlight relays, you will also have to run a +12v power lead from the battery to the red wire.
For you purists, the production panels will have a brown ground wire. The one in the picture is the prototype and I did not have any brown at the moment.
FEC3
Old 11-03-2011, 06:19 PM
nineball's Avatar
in that case please remove me from the other list. i would prefer it with the relay. thanks.
Old 11-03-2011, 06:28 PM
Recreational User
porschenut's Avatar
Fred, please add me to the list for a short panel!
Old 11-03-2011, 07:52 PM
Can this be added to the 1.0 version you just put in the mail for me?
Thanks,
Chris
1980 Targa, 3.2 upgrade
Old 11-03-2011, 09:52 PM
subscribed
Old 11-04-2011, 06:51 AM
tobluforu's Avatar
This looks to be an awesome product, but I want to hear about how hard it will be to re-wire all of those terminals, especially when you have no room like my 72. If it's easier then I think then I'm on board. When someone has this in hand and has an earlier car, please let us know.
Thanks.
P.S. I asked a question about the three panel fuse block in the engine compartment in the other thread, did you make one for this?
Old 11-04-2011, 07:04 AM
fred cook's Avatar
Questions
Thanks.
Sorry, no 3 fuse panel yet. I am just starting to work on a front panel for
the early cars. Done carefully it is not too difficult.
FEC3
Old 11-04-2011, 07:37 AM
Fred was kind enough to send me one of his fuse panels for evaluation and I was summarily impressed.
This is a VERY well made unit and should be a no-brainer for any of these cars using the OEM ceramic fuses which have always been troublesome, especially in humid climates.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-04-2011, 09:23 AM
BRLuecke's Avatar
Fred
Please add my name to the list with the head light relays
Brad Luecke
1988 Carrera Targa
Old 11-04-2011, 12:52 PM
Deadeye's Avatar
Fred, can you make a stripped down version of the original with just 10 circuits? That should be all I need for the track beast.
Old 11-04-2011, 02:27 PM
fred cook's Avatar
Track car version
Maybe, let me think on it for a bit. Would you want the short panel to bolt onto the same stock mounting bracket? Would you want the fuse holders centered or on one end? With or without relays?
FEC3
Old 11-04-2011, 03:07 PM
911 tweaks's Avatar
price please for this version w/ the 100w headlite relay...
Thx, BOb
I live for 911 tweaks...
Old 11-04-2011, 03:14 PM
Deadeye's Avatar
Fred, I will leave the stock bracket so your panel is fine. Fuse holders bunched towards the rear.
Old 11-05-2011, 04:09 AM
