bivenator's Avatar
cleaning your parts
Currently have the front end apart for some refreshing of bushings, and shocks. I want to clean the control arms, struts etc and repaint before the reinstall. What would the pelicans use to clean these items\?
Thanks,\
Scott
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates
88 coupe
Old 11-04-2011, 08:31 AM
I have had good luck with a cupped wire brush on the end of a drill, and then some brake cleaner to help clean up gunky spots. After they are free of all the junk, you can use a "Chassis Black" paint from the auto store. It has a nice hard finish, and you can get a gloss or a matte black finish.
Of course, the best way to go would be bead blast and then powder coating the arms.
Good luck!
1984 Porsche 911
Old 11-04-2011, 08:37 AM
Yes. I second the powder coat. It's the most resistant.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-04-2011, 09:06 AM
al lkosmal's Avatar
I've used both methods, with very good results.
Pressure wash, then wire brush, then carb cleaner and a toothbrush....followed by sanding, priming and painting..........................or
take it to the powder-coater and have them bead blast and powder-coat. (my preference)
RGruppe #669
http://www.x-faktory.com/
Old 11-04-2011, 09:11 AM
RETIRED
Joe Bob's Avatar
50/50 purple stuff and water.
2012 ML350 3.0 Turbo Diesel
Old 11-04-2011, 09:14 AM
Tired Member
DaddyGlenn's Avatar
Just did a similar project. Sent the control arms to Chuck ar ERP for his rebuild service. Blasted the strut housings and gave them a coat of rattle can primer and paint. Did the same blast and spray treatment with other bits, too.
Mine will go back to daily use so I wasn't looking for perfection. If I was, I'd powder coat everything and replate all the nuts and bolts.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 11-04-2011, 09:16 AM
Champagne on Beer Budget
HelmetHead's Avatar
Scott, My buddy owns a powdercoating shop in Kemah...if you want to go that route.
Friday Cheers!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 11-04-2011, 09:57 AM
cycling has-been
bkreigsr's Avatar
I used diesel fuel to clean my shocks and struts. Most everything else I tried removed the original green or orange paint. Diesel did not. Bill K
Old 11-04-2011, 12:12 PM
masterdave's Avatar
+1 for break cleaner, it's cheap and works. I have used everything from gas to rubbing alcohol to carb cleaner, it all works. Be careful with gas and what not on painted parts.
Regards
Dave
Old 11-04-2011, 12:57 PM
AutoBahned
RWebb's Avatar
Let the powdercoating shop deal with the cleaning - they have all the equipment (sand blasters, etc.) and do it all the time.
Old 11-04-2011, 12:59 PM
Evil Genius
Rusty Heap's Avatar
Use OVEN cleaner if you want to strip all paint and grease. Use gloves, nasty stuff.
Life is a big ocean to swim in.
Wag more, bark less.
Old 11-04-2011, 01:59 PM
