MSD Ignition and best Spark Plug Gap
Just installed the MSD 6 part no. 6420 Ignition Box. Hhave set my spark plug gaps at 1.40 mm and engine seems to be running ok. I have a 79 3.0. Is there anyone out there that has experimented with other gaps? porsche 101 suggests between 1.27 & 1.49 I believe. What tends to happen if you go smaller and if you go wider than 1.40? anyone....
Antares |
I have a 6AL and was running .90 as an experiment, my MFI runs SUPER RICH (haven't put my Gastester on it) and after about 2 minutes of idle (at 750-1000 RPM) the plugs begin to "pop" and are fouled. Folks say you can open the gap so wide you can stick a matchstick in there. Others cut half the electrode OFF.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Ditto for me, also a Weiner acolyte--3.2 twin-plugged SC.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Lemme see, .050" =1.27 mm
1.49 would be .05855 ~ .060" Looks like I'm going to have to buy a bigger feeler gauge.
Stephan & John
Before I put the MSD on I was running a permatune at around .70mm and no gassy or petroleum smell. With the MSD i installed it at 1.40mm gap and it's very gassy smelling at idle. Letting it run as I type and it's gasssing me out. So should i gap less for a hotter burn or even more. That is the question. Any thoughts? Antares wide body wannebe |
Author of "101 Projects"
The specified gap was just what MSD recommended. I think that the point they were trying to make is that the stock gap didn't work as well...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
