khamul02's Avatar
Lightbulb headlamp ignition electric bug
When I turn my ignition to the on position my turn signals and lights work perfectly. Then I crank the car moving the ignition switch forward slightly and my lights stop working. The only way to get them to come back on is to turn the car off and move the ignition switch back to the on position. Strange bug. Lights wont come on while the car is running. Any ideas?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 02-01-2011, 04:38 AM
khamul02's Avatar
Anyone? I can't drive at night
Tom Hutchinson
Old 02-01-2011, 09:55 AM
RETIRED
Joe Bob's Avatar
Lights are on when you start the car? Have you tried waiting to turn them on until it's running?
If they don't come on after the car is running, get a multimeter and test the output and input voltage at the switch. 12v in and nothing out, it's the switch. Nothing in, it's downstream.
2012 ML350 3.0 Turbo Diesel
Old 02-01-2011, 10:27 AM
khamul02's Avatar
Ok I will give that a try. One other note that is strange is that the dash lights work. It is strange. My thought was that the problem might be with the ignition as it is was is impacted the lights going on and off.
Tom Hutchinson
Old 02-01-2011, 06:09 PM
RETIRED
Joe Bob's Avatar
Dash lights and "parking lights" work on the first pull and when the engine isn't running at the second/full pull.
When the engine IS running the lights come on. Check both the high and low beams. You may have a defective hi/lo stalk.
Old 02-01-2011, 06:17 PM
khamul02's Avatar
Everything works perfectly when the car is not running. As soon as you move the ignition to crank everything goes off except the dash lights. I'm not sure the blinkers are even working once the key is in the "full on" position. Nothing I have tried will get the lights back on except turning the car off and putting the key in the accessories on (I guess it is called) position.
Tom Hutchinson
Old 02-01-2011, 06:21 PM
RETIRED
Joe Bob's Avatar
Do you have a wiring diagram or a Bentley? Sounds like the ignition switch.....
On the "everything" goes out, does this include running lights?
Old 02-01-2011, 06:24 PM
RETIRED
Joe Bob's Avatar
Old 02-01-2011, 06:30 PM
khamul02's Avatar
I have a Bentley.. again.. with all the lights fully functional until I hit the on position it just seems like it is the ignition. Once I have the car started only the dash lights work. It was interesting the other night driving home with nothing
Tom Hutchinson
Old 02-01-2011, 06:40 PM
RETIRED
Joe Bob's Avatar
Then check the diagram look for the lighting lead off of the ignition and look for the dead power lead. Could be the relays above the dash in the trunk.
Old 02-01-2011, 06:44 PM
The headlights on my 1976 911s do the same thing sometimes. I have to jiggle the ignition switch to get the headlights to start working again.
Old 02-01-2011, 06:51 PM
muck-raker
kidrock's Avatar
my money is on a bad ignition switch. Maybe a removal and a good cleaning will solve the issue. I'd check all applicable grounds as well.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-01-2011, 07:20 PM
Tom,
The 911 ignition switch assembly comprises two separate sections. The mechanical (key & lock) and the electrical (tumbler) where all the electrical connections are mounted. The hardest part is removing the electrical switch (tumbler) and once you are able to separate it from the key/lock section, you could actually be able to start the car without the key.
You need to inspect the ignition switch assembly to determine the problem. Remember there are 2 major parts involve in the operation of the ignition switch. The mechanical and electrical parts. You'll be doing a lot of guesswork in your troubleshooting if you don't inspect the IS assembly. HTH.
Tony
Old 02-01-2011, 08:38 PM
khamul02's Avatar
Thanks everyone. I will pull the ignition in a day or so. It has to be the problem as I now have noticed my wipers are working the same way as my lights.
Tom Hutchinson
Old 02-02-2011, 07:28 AM
khamul02's Avatar
Whelp, It was in fact my ignition switch. It looked newish.. but the upper screw had not been installed ... probably out of laziness. When I removed the lower screw the whole ignition switch fell apart.. The thing was screwed... Anyway .. new one installed using the short screwdriver technique and all is well.
Tom Hutchinson
Old 02-26-2011, 08:41 PM
Bad IS?
My 1984 911 targa has been running great.
However, I accidentally tried to start it yesterday while in first gear.
Lurched a bit and did did start.
On my very next turning of key, still did not turn over.
Lights etc all work fine and I hear the fuel pump whirring away, but no starter turn over or click of the solenoid.
Could this one bad start of mine have fried out my otherwise working Ignition switch?
BTW, had my sons come give me a push yesterday for a bump start, it fired right up and drove fine all the way home.
Turned off in garage and again nothing when starting with key.
Also, is there a way to replace IS without removing from dash?
Upper screw on IS electrical portion seems impossible to reach from underneath?
Thanks!
Old 11-26-2011, 11:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks!
Rick,
Do a search-Ignition Switch Removal. Lots of help waiting for you there!
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-26-2011, 11:51 AM
OK.
Pretty set on how best to take it out now.
Thanks.
But do you think this miss-start in gear would have fried the switch?
Old 11-26-2011, 07:38 PM
