1986 Coupe - Stereo Wiring Quick Question(s)/ Advice
So, while cleaning up the wiring and checking things over:
Photos below are of my 86' Coupe and the previous owners wiring for an aftermarket head unit: Photo 1: ![]() Photo 2: ![]() Photo 3: ![]() Head unit/stereo lines are tied into the wires from the ignition switch to headlight switch as seen above. Both fused 40a and 10a constant and switched wires respectively.. My question is: In the above photos is this the best place to wire the head unit in and are the fuses correct. 10a and 40a don't seem right??? Is there a better constant and switched power source to tie into??? I have searched the threads and seems some run constant/permanent power (fused) directly from the battery??? I have recently developed an issue at startup where 1 time out of 10 the head unit will not come on AND the headlights will not work. Most times if I restart the car they both work fine... Thanks for any input! Erik
1986 911 Coupe 1986 911 Targa |
Makes no sense. Where is the stock radio harness? That should provide both constant power and switched power, as well as ground. There should have been no need to tie into the headlight wiring at all. Ironically, the largest fuse in this car should be 25A. However, by default not all wires for the headlights are fused (which is why most people add in the aftermarket relays for high and low beams). Perhaps that's why they added the fuses.
I'd yank all that crap off, add the proper relays to the headlights, and find the proper radio harness behind the radio unit. Then tap into that if you really want to retain the aftermarket head unit.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus Last edited by wrxnofx; 01-05-2023 at 02:15 PM.. |
Been here a while
without the stock radio wiring, I'd go to the fusebox directly and find some switched and constant feeds that are unused, maybe you don't have a sunroof or heated seats or something.
For constant power, you could go straight to the battery, with a fuse of course. 40amp is way too much, unless you have an outboard amp. Typical 10watt maybe up to 20 if it's a real "high power" radio.
looking for 1972 911t motor XR584, S/N 6121622 |
Just finished this on my car. There should be both switched and constant power available. Confusingly, the colours are reversed from normal - yellow for switched, red for constant. If the stereo has lighting tied to the headlights, you can easily build a blade adapter to tap into the wire on the ignition switch and therefore not cut or damage any wiring. Ground I just used an existing hole in the dashboard.
I'll never understand these hackjobs. It's not that hard to do it right.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
I believe that the old Blaupunkts had a wiring option whereby the radio could be connected to the headlight wiring. The idea was that the radio would detect when the headlights were switched on and would automatically dim the lights on the radio’s faceplate. This may explain why the radio wiring was tied in to the lights.
Thanks everyone for the input so far!
So I will be tearing out the wiring from above and starting from scratch. Few questions from the experts here: 1. Running a direct line (constant) from the head unit to the battery what gauge wire would you recommend??? I'll be adding an inline fuse of course and it seems like 15 or 20a would be the best. 2. Where have some of you tied in for switched power? ** With the head unit I do not have a need to tie in for illumination - so not worried there. ** Speakers I have finally worked around the fader and used new wires to all four speaker areas. 9 volt battery is your friend there ![]() I have never used a direct line to the battery so this is new to me (always had a harness or paid to have the work done) - thus all the questions. I want to do this install myself so appreciate the help. Erik
Have headlight and dash light relay threads printed out and will be adding those over the next few weeks. Thanks!Quote:
Going with 15a fuse most likely straight to the battery. Thanks! Quote:
I noticed that too - red and yellow are reversed. The lighting on the stereo is tasteful and controlled easiest from the head unit itself - good idea for the future though. Quote:
Again, thank you so far...Just replaced the ignition switch (pain in the ass job) and wiring through the door jams for the plungers (even worse pain in the ass job) to the dome lights - which were cut like all other wiring. I now have dome lights and power windows that actually work properly after shutting down the car. Always wondered why my windows worked all the time - now I know. Well, back out to the workshop... Erik
Been here a while
My various cars, SC's of various years mostly, have an extra 10mm nut on the battery post with a couple of factory high-draw loads attached right there, it's easy to put a ring terminal on a piece of wire and attach there. I suspect you want 10 or 12 gauge, based on load and length.
Also, consider using an open spot on the fuse panel. For example I hooked my subwoofer to the unused headlight squirter spot. Personally I've never cared for inline fuses, it makes for difficult diagnosis down the line.
You should check out diymobileaudio.com and caraudiofabrication.com (the latter has lots of how-to videos, both offer good advice via search function). The most important thing is sizing the wire to the power requirements of your amp; the fuse protects the wire so that you don't start a fire!
Analog Air Cooled
I just tee’d off of my orig harness. I use the stock set up plus there’s a fuse in the radio. I retired everything to stock in my car.
I will tap into a vent light for the orange night dim switchable wire.
86 Targa 91 964 13 6 SPD Cayenne |
Hey, I did the work last year.
As you can see, I was unsure over which path (the permanent power or the ACC power) the radio draws its power, and which one is just for 'signalling purposes' or perm memory. I probably should measure it one day.
__________________ 1985 Carrera 3.2 |
Found some of the original harness I believe. They were mostly cut and were crammed wayyyy up under the dash. I am not sure what some of the connections are for radio, speakers??? I'll upload some photos with some questions.
These are the wires I found today. 1. yellow and brown 2. black/blue stripe and brown w/connector 3. blue/black stripe and w/brown/connector 4. yellow/red stripe and black ![]() -------------------------------------------------------------------------------------------------------- Here are the two I am not sure of - not using but am curious what they are. ![]() ![]() ---------------------------------------------------------------------------------------------------------- yellow/red strip and black Tested for power constant and switched/ACC and got no readings - couldn't find any other posts describing yellow w/ red stripe along side the black wire. Not sure what these wires were used for. Let me know if you've come across this before. I assumed it was for power but wouldn't use anyway - running a direct line to the battery. ![]() ------------------------------------------------------------------------------------------------------------------------------- yellow and brown Tested the yellow and got a reading with the ignition on (ACC). No reading with ignition off. Brown I assume is ground. I found one post out of 100 that had the same yellow wire being used for ACC. Found here: ((https://forums.pelicanparts.com/porsche-911-technical-forum/1111943-radio-wiring-help-needed.html)) Question for everyone: Would this wire be fine for my modern stereo as the ACC wire??? Very very conflicting opinions... I did a primitive dry run and hooked things up and everything worked well. Just concerned about draw on the wire with a modern head unit vs the original equipment. ![]() I will be running a fused wire (15a - debated on 10a) directly from the battery and not quite sure about using the original harness with this new head unit even as an accessory connection. Would love to get rid of all of this original wiring but will clean up and keep under the dash - learned the hard way long ago not to just cut stuff off to clean up wiring ![]() Finally got a new heat gun and will start working on new wiring...will check in here for new input. Can't thank you guys enough for the responses already. Probably should have documented this more with photos and images of wiring diagrams. Hopefully this will help others down the road. Again, thanks guys! Erik
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 01-08-2023 at 06:25 PM.. |
You might find some help with you wiring here:
https://www.modifiedlife.com/porsche-radio-stereo-wiring-diagrams/
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
Thanks! Erik
Great stuff! Thanks! Erik
Analog Air Cooled
The blue and browns are your lights for your hvac. Get some 1.2v bulbs and stick them in. Test if they have power and they are dimable.
Analog Air Cooled
The yellow red stripe is the DEF icon light coming from the black wire that goes to cig lighter.
The other 2 need bulbs and power the HVAC lights
Man, that makes sense if that's the case. Sometimes things are right in front of you and you just don't see it. I don't drive much at night (Hill Country Texas...a lot of deer) so I have never noticed dash lights or lack there of in this car. I'll check tomorrow. Thanks!
I see three slots for bulbs in a face plate but I of course have two bulb connections at this point - looks like fan light (right), direction light (right) and on the left a place for a bulb which would be defrost. The previous owner also cut the wire to the light on the floor board by the heat levers.
1986 911 Coupe 1986 911 Targa Last edited by fallingat120mph; 01-09-2023 at 08:08 AM.. |
