1983 911SC Cabriolet. Top catch above the windscreen latches the top with some downward pressure from the outside. Occasionally while driving down a rough road or during highway speeds the catch slips from windscreen latch hole thus letting the top fly open while the car is moving. Is there an adjustment for the catch or another method to secure top....Porsche part # 911 565 031 41...thanks
RETIRED
Take a look at the pins that are in the top. They depth can be adjusted to create tension when the latches are engaged.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Joe Bob,
Can you share any details about how to adjust the depth of the pins? This may solve a longstanding problem I've had with latch tightness and resulting wind noise. Thanks, David
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
RETIRED
Pull your top down and take a pic of the pins that stick striaght up....post it. It's raining and will be for the next three days, otherwise I would.
Here you go...
RETIRED
Loosen the lock nut, bring the pin out deeper.
