Vereeken's Avatar
Thermostat o-ring SC
My internal oil thermostat on my 83 SC needs a new O-ring. To my surprise I pulled the thermostat only to find a squared of BLACK O ring.
The replacement send to me was a GREEN-ish rounded O ring.
Is this normal? So if you look at the picture I would replace the black O ring with a rounded GREEN O-ring.
Any reason why this was changed? The Green O ring carries the Porsche OEM sticker
Or am I missing something?
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 11-14-2011, 07:52 AM
arbita1's Avatar
Yes. I believe there are different colors from different manufacturers.
Matt.
83 911SC
85.5 944 NA - Sold
Old 11-14-2011, 08:40 AM
1979 911sc
Windsor4273's Avatar
Ha. I just posted a question wondering if the car has a thermostat and here you even have a pic of one! Where is that located and how to I check mine to see if it is working? Car never warms up to normal temp....
Old 11-14-2011, 08:57 AM
Vereeken's Avatar
Thermostat is number 4 back in the engine compartment. You can remove it with engine in car if you are skin and bones. Be carfull not to drop anyting in the hole.
Old 11-14-2011, 09:18 AM
Vereeken's Avatar
yes, just read that the black ones are no good. Wonder why Pelican still sells them.
Old 11-14-2011, 09:20 AM
Northern Motorhead
wildcat077's Avatar
I just replaced mine a few weeks ago after i had the engine out.
The OEM one was black plastic and the new one i puchased from the dealer was a green rubber "O" ring !
The parts guy told me that the original black plastic sealing rings had been superceded twice ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-14-2011, 11:41 AM
Vereeken's Avatar
Clear. Thanks
Old 11-14-2011, 12:19 PM
db_cooper's Avatar
Online..PP has two "O" rings listed..one red,,the other green.
I fitted the red thermostat "O" ring. It went in the case with near no resistance..and it "weeped" oil.
Removed the thermostat.
Installed a green "O" ring..it had some resistance when installing and is dry..no leaks.
Can't speak concerning the black"O" ring. My advise..use the green "O" ring.
Old 11-14-2011, 02:52 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by db_cooper View Post
my advise..use the green "o" ring.
+1
Old 11-14-2011, 05:02 PM
I havent seen a black one that didnt fall apart and crack when being removed. I had a green one leaking and reinstalled it with a red one.
Bruce
Old 11-14-2011, 05:50 PM
