Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Question bearings ?
Please help me witn this ?
I will replace my 74 m calipers suspension bearings.
I want to know if I neeed replace all this parts:
Front Outer Wheel Bearing, 911/911 Turbo (1974-89) [Photo]
K-059-065-00 $8.80
Front Inner Wheel Bearing, 911/911 Turbo (1974-89) [Photo]
K-059-098-00 $8.80
Front Wheel Seal, 912E, 911/911 Turbo (1974-89) [Photo]
477-405-641 $6.90
Front Wheel Spacer, 911/911 Turbo (1974-89) [Photo]
A-341-623-00 $39.95
Front Wheel O-ring, 911/911 Turbo (1974-89) [Photo]
K-701-084-50 $1.50
Front Wheel Thrust Washer, 911/911 Turbo (1974-89) [Photo]
C-341-663-00 $4.95
Front Wheel Clamp Nut, 911/911 Turbo (1974-89) [Photo]
C-341-673-00 $35.00
Front Wheel Bolt for Clamp Nut, M7x18mm, 911/911 Turbo (1974-89) [Photo]
K-119-001-01 $1.95
Front Wheel Dust Cover, 911/911 Turbo (1974-89) [Photo]
C-341-684-00 $15.95
Front Wheel Dust Cover, 911 Turbo (1986-89) [Photo]
H-341-066-01 $48.95
Any comment or sugestion ?
Let me know
regards
Old 03-26-2002, 12:21 AM
If your wheel bearings are bad just replace those along with the seals. I just did mine. The bearing races in the rotor hub were a ***** to get out. I heated up the rotor which helped.
1974 911 2.7L coupe with sunroof
Old 03-26-2002, 06:30 AM
KTL KTL is online now
Schleprock
KTL's Avatar
If you're going to replace the bearings, you ought to replace the races as well. They're precision matched components. That's why a new bearing comes with the new race!
I don't think you need to replace the clamp nut, clamp nut bolt, or thrust washer (you can flip this over if worn on the bearing side- not likely) unless they're damaged. You don't need the last part listed (911 Turbo dust cover).
Probably don't need to replace the spacer and o-ring either. Spacer is a little tough to get off as it's pressed onto the spindle. Just do the bearings and inner seals as htbetz said and you should be fine.
Kevin L
'86 Carrera "Larry"
Old 03-26-2002, 06:40 AM
Thumbs up
Thanks for your answers
Old 03-26-2002, 12:42 PM
What are the racers ?
appears on my list or in the draw attachment ?
Old 03-26-2002, 02:51 PM
Schleprock
KTL's Avatar
Races aren't shown in the above diagram. They are hardened metal rings that are press-fit into the axle hub. They are included with the bearing when you buy a new bearing.
Kevin L
'86 Carrera "Larry"
Old 03-26-2002, 08:26 PM
Ok, I already undertsand !
Yes, I will change this
regards
Old 03-26-2002, 08:40 PM
