76 2.7 need help with idle adjustment
i need some help with idle adjustment ,car starts easily seems to run ok ,i just installed MSD box and coil ,new plugs ,plug wires ,dist. cap,also need to know how to adjust fan belt ,this is my first porsche 911 ,ihave the haynes manual,but is does not really tell you how to make the adjustments,unless i just do not understand .
Old 11-11-2011, 05:44 PM
76 911S Targa
On the air box, on the left forward corner is a slot head knurled screw about as big as your finger. Although you could use a screwdriver to turn it, you can also turn it with your fingers. Turning it in, clockwise, reduces the air flow through the air metering funnel which lowers the idle speed. Turning it out, counterclockwise, increases the air flow and the idle speed. You need to learn how the fuel injection system works. Print this pamphlet and read it carefully: Bosch K-Jetronic Fuel Injection Manual
Good luck!
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 11-11-2011, 06:08 PM
Targalid has given you the directions for adjusting the idle however, his suggestion to read up on the CIS is the most important for you. You may find the idle screw is ineffective or you do not get a smooth running engine. If so, you likely have other issues common to older CIS systems most of which are easily fixed. So this is just a heads up to do some reading and feel free to post questions here or do a search if needed.
As far as the fan belt, it is adjusted by adding or removing shims from between the pulley halves on the alternator.
If you need to tighten the belt, remove the pulley bolt and cone washer, separate the halves, remove one shim, replace the outside pulley half, put the removed shim between the pulley half and the cone washer, and tighten the nut. Test the tension. Repeat the process if you need the belt tighter, one shim at a time. (Use caution when reassembling the pulley to ensure the belt is centered and the halves are parallel.)
Important: you should have a total of 6 shims, distributed between the pulley halves and the outside washer at all times.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-12-2011, 09:59 AM
