Stian911's Avatar
My 911 broke down 2night- ignition trouble?
Hi guys,
My first post on the forum
I live i Norway and bought my first Porsche 964 from California this summer.
Tonight, on my last drive for the season, my engine startet to make "poffing" sounds whilst driving. It got worse and worse and I had to stop. I had lost almost all power on the engine and it was running rough. The catalyst was read hot.
I got my car back to my garage on the back of a truck.
Any tip of what to do?
Kind regards
Old 10-23-2011, 04:22 PM
What year is your car and how many miles are on it?
Catalytic converters can become plugged after many years and they will cause your engine to quit running. One of the symptoms of a plugged converter is they get red hot and glow.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 10-23-2011, 06:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It a 964 so post 89. Wow RED HOT too bad no pics
What type of gas and oil are you using? +1 clogged cat. If it is it, get a pre-muffler or sport cat.
Check your cap and rotor too.
'85 Carrera Targa
PCA/POC
Old 10-23-2011, 07:52 PM
Stian911's Avatar
Hi,
It is a 1990 model. (One owner car- got to love the U.S :-)
It has run 60 000 miles.
If the Catalytic get plugged, will it run poorly, or will it just stop?
It felt like it was running on one less cylinder. Kind of....
Old 10-23-2011, 10:05 PM
Stian911's Avatar
Unleaded 98 and Mobile 1 (5W-50)
If it is the cat would you just remove the darn thing? (better sound and performance- right?)
Old 10-23-2011, 10:21 PM
Stian911's Avatar
Thank you both for quick reply!
Old 10-23-2011, 10:22 PM
DRACO A5OG's Avatar
Yes more top end power and deeper base sound.
Wow 98, you mean 98RON, correct?
In anycase, if it felt like a cylinder, then check the Cap and Rotor as well. Also in a dark garage, while the engine is on, open the engine lid to see if you get errand sparks, maybe a spark plug dislodged
'85 Carrera Targa
PCA/POC
Old 10-23-2011, 10:26 PM
Red hot catalytic converter usually means to much fuel going through the engine. Possible missfire on one or more cylinders. You will have to diagnose the ignition and fuel injection. You can do a compression test to make sure the engine itself is still ok.
-Andy
Old 10-23-2011, 10:53 PM
Stian911's Avatar
Thank you all for taking your time!
I will start to investigate this evening
Old 10-24-2011, 02:49 AM
Stian911's Avatar
How likely is the "distributor drive belt" the reason for my troubles?
Anyone experienced problems with the distributor belt? Difficult to change?
-S
Old 10-27-2011, 12:52 AM
-S
If it has never been changed, most likely. Pull out both distributor caps and spin the left side rotor. If it spins, belt is broken.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-27-2011, 03:15 AM
Stian911's Avatar
Thank you, I will give it a try....
Old 10-27-2011, 06:02 AM
tdatk's Avatar
Was it raining/roads wet? I had my flywheel sensor do this when it got wet.
Tim
82 SC
90 C2
Yasowatt
Old 10-27-2011, 08:19 AM
Stian911's Avatar
The road was dry. No rain in sight.
I opened the distributors last evening. The drive belt was broken. The rotor was moving, but the belt was not moving at all. So I guess that`s what caused med problems.
I have also removed the cat and replaced it with a "dummy" which is empty.
Old 10-29-2011, 11:46 PM
Stian911's Avatar
Help needed!
Anyone who can tell me how to replace the belt between the two distribrutors?
I have removed the cap on both distributors, but it is hard to see what to remove in order to get to the belt.
Old 01-02-2012, 09:34 AM
RETIRED
Joe Bob's Avatar
distributor belt replacement - thread collection - Rennlist Discussion Forums
Looks like you'll need to remove the unit and dissasemble....
2012 ML350 3.0 Turbo Diesel
Old 01-02-2012, 10:53 AM
Stian911's Avatar
Thank you Joe Bob! GREAT help!
I will remove the distributor tomorrow and have it sent away for a rebuild
Old 01-03-2012, 01:48 PM
Just hope you didn't damage your pistons from preignition.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-03-2012, 05:10 PM
Stian911's Avatar
I donīt dare to think about it!
At least there is no oil leak...Hope thatīs a good sign?
Old 01-04-2012, 02:16 AM
Stian911's Avatar
The distributor!
Old 01-04-2012, 02:19 AM
