Just got my Bendpak MD6-XP need help with ramps
Hi all,
Finally got my Bendpak MD-6XP lift home. I need to make some sort of ramps to raise car enough to clear the lift pads. Could someone direct me a link that has dimensions for the wood pieces? I know it will be 2 X 12's about 12' long. But would like actual dimensions for long pieces and the ramps I'll need to make so I can drive car up on the 2 X 12's. I've seen some neat looking set ups in the past but can't seem to find them now. Thanks, David
'89 3.2 Carrera Coupe-Silver Anniversary-sold '06 GTI/DSG |
UnRegistered User
One of the guys that lives near me has this lift.
His solution was to remove the lift pads from the arms and his SC would drive right over the lift. I do remember he had some type of plastic tile/flooring down so maybe that increased his clearance.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
You know...that would work. I planned on using hockey pucks between the lift pads and the jack points on the car. Suppose I could just put the hockey pads directly on the lift arms and then raise the lift.
Thanks, David
Slippery Slopenose Victim
Joined the scissor lift owner's club!
Show me your scissor lift ramps Scissor Lift - Brag About Yours and Your Set Up I like this last set-up............. BendPak SP-7X Lift Purchase Question
sxsman@hotmail.com Have guns , will travel Mr. Potato-head , 1974 911 Slant/turbo look 2.7 1963 Cooper S ex-C sedan , 1974 Vespa Rally , 1974 TVR 2500M (sold) ( Musta had massive head trauma in 74 , ya think ? ) |
Thanks for the links!
i used a set of old steel ramps i had as none of my cars can drive up them due to the steep incline. i left a few inches of the "top" on there which serves as a backstop so the car won't move (the garage floor slants slightly forward).
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
83 911 Production Cab #10
Base: Two 6' long 2" X 12"
Top: One 10' long 2" x 12" Ends bevel at 45 degree Both ramp tie to each oder so they spread out when you lower the car
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Here are the ramps I made for my mid-rise.
I made them out of 3"X 2" and covered them with 3/4" outdoor grade ply. The main sections are 108" long x 16" wide - I had to go wide due to the large difference in track on my RSR. ![]() ![]() For the ramp section I ripped sawed some 40" lengths of 3" X 2" diagonally across and then capped these with 40" x 16" X 3/4" ply. ![]() These are relatively lite to store when working on the car (I drag them out of the way) and I can push the car up the ramps on my own. Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. Last edited by motley911; 11-13-2011 at 09:14 AM.. |
A big plus on this design. I used the 2 x 12's and the are very heavy. If light you can move them out of the way when you are working on the car.
Dan |
Thanks Dan - I move the ramps out of the way whenever I am doing major work on the car - you can see them stacked against the wall in the left hand side of this photo.
![]() I made the ramp section separate so that I can just remove them when working on the engine / gearbox Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. |
Light is good,
I used a combination of pressure treated wood and aluminum deck planking that we had laying around. If you add work extensions off the side then you won't have to move them These are 2' on each side . Put plastic sheet vapor barrier under everything too and some kind of metal plate for the rollers and pivot to ride on, again I used some scrap hull plugs that were laying around ![]() ![]() Being able to roll up any carpeting for messy work is a good idea ![]() An array of lifting buffers is handy too ![]() Don't forget a drip tray under the engine, some cars are just so low that an removable layer is necessary, such is the case w/ my blue car
