-   -   How do trailing arms differ? (http://forums.pelicanparts.com/porsche-911-technical-forum/640138-how-do-trailing-arms-differ.html)
irl 11-15-2011 07:21 PM
I am restoring a 74, and I am updating many parts. How do trailing arms differ from 74-89 or are they all the same.
frankc 11-15-2011 08:08 PM
In 78 the connection point for the sway bar drop link changed from a ball post attached to the TA (how the post is attached seems to be a bit of a mystery), to a standard bolt fastener. This only matters if you want to use an OEM style sway bar because most others appear to mount the drop link at the spring plate.
btw, let me know if you are looking for a set of 74-77 style Trailing Arms.
irl 11-16-2011 06:39 AM
Are they all aluminum?
Flieger 11-16-2011 09:51 AM
Post 74 all are Aluminum.
BK911 11-16-2011 09:57 AM
I thought the '74 was a one year only and the sway bar mount changed in '75?
RWebb 11-16-2011 12:01 PM
not sure when that mount changed
the Al arms are lighter, stiffer, and IIRC stronger than the old steel ones
at some point, P AG put bigger rear wheel bearings into the Al arms, so the wt. went back up a bit
Cory M 11-16-2011 01:30 PM
If anyone is looking: I've got a nice pair of aluminum arms off of a 1976, complete with new Elephant Racing monballs installed. Send a PM if interested.
Shaun @ Tru6 11-16-2011 01:51 PM
74 to 89 are all Al.
There is no reason for you to update if you have good 74 Al arms. If for some reason you do use a later year than 74, make sure you keep the stub axles in the arms as they are 69-74, having 4 bolts and 2 pins to match to the CV joint.
frankc 11-16-2011 06:13 PM
There is some more info here about the sway bar mount for 74-77 vs. 78+ trailing arms:
http://forums.pelicanparts.com/porsche-911-technical-forum/550663-1974-1977-sway-bar-question.html
http://forums.pelicanparts.com/porsche-911-technical-forum/381841-77s-sc-drop-link-conversion-questions.html
http://forums.pelicanparts.com/porsche-911-technical-forum/301988-911sc-rear-suspension-swaybar.html
And many more links if you search for " trailing arm drop link ball"
irl 11-16-2011 06:53 PM
great everyone, thank you for the time. This place continues to amaze me.
