irl irl is offline
irl's Avatar
Send a message via AIM to irl
How do trailing arms differ?
I am restoring a 74, and I am updating many parts. How do trailing arms differ from 74-89 or are they all the same.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-15-2011, 07:21 PM
frankc's Avatar
In 78 the connection point for the sway bar drop link changed from a ball post attached to the TA (how the post is attached seems to be a bit of a mystery), to a standard bolt fastener. This only matters if you want to use an OEM style sway bar because most others appear to mount the drop link at the spring plate.
btw, let me know if you are looking for a set of 74-77 style Trailing Arms.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-15-2011, 08:08 PM
irl irl is offline
irl's Avatar
Are they all aluminum?
79 SC unmolested
25 GTS
Old 11-16-2011, 06:39 AM
Max Sluiter
Flieger's Avatar
Post 74 all are Aluminum.
Old 11-16-2011, 09:51 AM
Home of the Whopper
I thought the '74 was a one year only and the sway bar mount changed in '75?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 11-16-2011, 09:57 AM
AutoBahned
RWebb's Avatar
not sure when that mount changed
the Al arms are lighter, stiffer, and IIRC stronger than the old steel ones
at some point, P AG put bigger rear wheel bearings into the Al arms, so the wt. went back up a bit
Old 11-16-2011, 12:01 PM
Cory M's Avatar
If anyone is looking: I've got a nice pair of aluminum arms off of a 1976, complete with new Elephant Racing monballs installed. Send a PM if interested.
Old 11-16-2011, 01:30 PM
Shaun @ Tru6's Avatar
74 to 89 are all Al.
There is no reason for you to update if you have good 74 Al arms. If for some reason you do use a later year than 74, make sure you keep the stub axles in the arms as they are 69-74, having 4 bolts and 2 pins to match to the CV joint.
Tru6 Restoration & Design
Old 11-16-2011, 01:51 PM
frankc's Avatar
There is some more info here about the sway bar mount for 74-77 vs. 78+ trailing arms:
1974-1977 Sway bar Question.
'77S to SC Drop Link Conversion Questions...
911sc Rear Suspension & Swaybar
And many more links if you search for " trailing arm drop link ball"
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-16-2011, 06:13 PM
irl irl is offline
irl's Avatar
great everyone, thank you for the time. This place continues to amaze me.
79 SC unmolested
25 GTS
Old 11-16-2011, 06:53 PM
