Loss of Horsepower
Hi Folks,
New to the forum - found some great stuff here but my searches hasn't revealed a cause of my loss of horsepower.
Here's the background. My car is an '87 911 Carrera w/ 3.2 sitting at 93K miles. I just installed a Fabspeed pre-muffler and dual outlet muffler. Valves were recently adjusted and new plugs and wires installed. I haven't done a compression check but the car doesn't smoke and has normal oil consumption.
I could feel some sloppy throttle response up to 4K rpm and then it smooths out and pulls pretty good but it just felt down on power. I put it on a chassis dyno today and it was confirmed - peak hp was just 138. The A/F mixture was showing all over the place - rich at the beginning and leaning throughout the mid and upper range 14 - 15. I did a check on the sensors and everything was showing correct voltage and correct continuity/ohms. I did a check on the flow meter and it seemed to be functioning ok but when I checked the ohms through the range of its operation it showed from ~550 to ~1100 up to about halfway open and then dropped back down to ~600 as it went to full open. Anyone know if this is normal?
Anyone got any ideas on where the hp has gone?
Old 11-18-2011, 05:47 PM
DanielDudley's Avatar
Do a compression check ? What if your valves are bleeding off compression ?
Old 11-18-2011, 05:59 PM
Member 911 Anonymous
DRACO A5OG's Avatar
If you can swap out a known good AFM if it clears up then there is a thread from the 944 forum how to re-fresh the AFM potentiometer.
Oh yeah, Welcome Home
'85 Carrera Targa
PCA/POC
Old 11-18-2011, 06:07 PM
steely's Avatar
Here's the link Jim mentions - the potentiometer wiper wears the material away, so your readings weren't normal. I had to hunt as the URL changed. Welcome and good luck. Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-18-2011, 08:37 PM
Did you change software???
If not, that's the first major issue as your exhaust changes really affect AFR's.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-19-2011, 12:46 AM
Thanks for the welcome and for the ideas. I did not update the software, next thing to change. I suspect a bad/worn AFM due to the erratic readings. Thanks for the link. I will delve into that this weekend.
Old 11-19-2011, 06:51 AM
Have someone sit in the car and floor the throttle pedal while you check to see if the throttle can be opened further at the throttle body. Many 911's that are down on power have worn out linkages and it is a nice surprise when you actually get full throttle.
Paul
Old 11-19-2011, 08:26 AM
Thanks I'll check the throttle linkage as well. Did take the DME apart and found it had been chipped with an older ('95) Autothority chip. Thinking maybe a Wong chip replacement would help?
Old 11-19-2011, 10:21 AM
Northern Motorhead
wildcat077's Avatar
Wong chip is definitely a "need to install" thing ... plus you get all the necessary, and more
outstanding customer support from Steve !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-19-2011, 11:34 AM
