Location: Vilnius Lithuania (it's in Europe and it's not Russia)
need help fitting 86, 930 horns back
hi, could someone post a photo how horns that are in front of oil cooler under passengers wing should be fitted. I have removed everything and now can't remember how to put it back...
Member 911 Anonymous
Sorry no Pics,
But you should have a bracket/bar that mount to the top portion of the fender (wing, as I recall the top portion) then you mount the two horns with the horn openings facing down to the ground. You must make sure it is tucked in up the fender so you can not see from the side view. Maybe other will post a pic. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
thanks, but still would be great to get a photo
