Alignment Settings
Hi All,
I putting some Turbo Tie Rod's onto my 1983 SC this weekend (as well as rebuilding the front calipers!), and will need to have it re-aligned afterwards. Do I need to have a full alignment done, or will it just be the toe that will be out? Also, can anyone recommend settings for camber/caster/toe etc.. for 90% street 10% track use? Cheers, Tim. ____________ 1983 SC Targa |
Tim
Here's a street/track compromise that works pretty well: Front Rear Camber -1 deg -1.5 deg Caster 6-7 deg N/A Toe 0 -15' (toe-in) |
