-   -   911 3,2 row 1985 whit 915/72 if possible fit g50 87/89? (http://forums.pelicanparts.com/porsche-911-technical-forum/641279-911-3-2-row-1985-whit-915-72-if-possible-fit-g50-87-89-a.html)
dan67 11-22-2011 09:44 AM
hi! i have 911 3.2 row 1985 whit 915/72 (radiator oil) if possible fit the G50 for 3,2? (/00 or 01 or 02 ) i see here the differences :
California Motorsports Porsche G50 5 speed transmission section
is fit, fit WHITOUT shift modifications? (on 915 shifter)
thanks!
db_cooper 11-22-2011 10:03 AM
Anything can be done with dollars and time. Its not a bolt in. Late 915 gearboxes were very good. Use it and keep the car original.
KTL 11-22-2011 10:57 AM
G50 swap requires quite a few modifications to swap into a 915 car. Shifter, main shift rod, clutch, pedal cluster, probably your axles and transmission size are all different.
