911 3,2 row 1985 whit 915/72 if possible fit g50 87/89?
hi! i have 911 3.2 row 1985 whit 915/72 (radiator oil) if possible fit the G50 for 3,2? (/00 or 01 or 02 ) i see here the differences :
California Motorsports Porsche G50 5 speed transmission section is fit, fit WHITOUT shift modifications? (on 915 shifter) thanks!
---the difference between insanity and genius is success-- |
Anything can be done with dollars and time. Its not a bolt in. Late 915 gearboxes were very good. Use it and keep the car original.
Schleprock
G50 swap requires quite a few modifications to swap into a 915 car. Shifter, main shift rod, clutch, pedal cluster, probably your axles and transmission size are all different.
Kevin L '86 Carrera "Larry" |
